BRUMBY Front strut top hats
Hey guys im in need of some brumby front top hats.
Ive installed brumby adjustable front struts in my L series but the L series top hats dont allow the top of strut thread through far enough.
if you can contact me on 0435791129 or [email protected]
thanks yarran
thanks yarran
cheers steptoe
steptoe wrote:They'd be any MY, just ensure they fit witht he rubber lump towards the rar side of the hole in tower for 4WD, think they are marked VAN/FWD with arrows so VANs and FWD are fitted with lump towards the front of the hole.
will i need the upper mount and the upper spring seat?
I have never seen the brumby upper mounts in person but have heard of people using them.
do you just use two out of three of the holes in the L series,
and with the rubber lump to the far side, as in away from the engine?
having trouble finding one
no wreckers will sell them!!
Pretty sure i will need #14 #10 #15
http://www.buysubarupartsnow.com/auto-p ... ly=7560804
can anyone shed some light?
Unable to see the pic???Yarran wrote:Pretty sure i will need #14 #10 #15
Do you have a lift kit? Could you convert the 2 bolt to 3 bolt via the lift block?
This is were the picture is.RSR 555 wrote:Unable to see the pic???
I'm on my phone at work so can't post a link.
And nah no lift kit I jut cut and bashed till 26" wouldn't scrub.
I was assuming I could maybe just use two of the three mounting holes? If they line up that is...
I was thinking today I might be able to drill out the L series upper spring mount so the strut sits inside the seat instead of under it to give me altitude more thread to play with.
Would re-drilling the L strut mount holes be a bad idea?TOONGA wrote:You won't get an MY top hat to fit unless you either re-drill the suspension mount in the "L" or make an adaptor block. I must ask are you using a spring compressor.
Yes I used a spring compressor to remove old suspension and install the Brumby struts and new springs.
Yeah I was thinking of something along those lines thanks steptoe!steptoe wrote:I have seen the result of a kit fitted to some other make where a top was fitted with extra mounting studs, so new holes made. Kit came with reinforcement washers for those redrilled holes. You might consider doing same with reasonably solid washers
I was just thinking, why not just use L.Series adjustable shocks?
Would have been easier yes
Frog had a new pair of OEM struts and I couldn't find any L series ones at the time.. You have a spare set RSR 555?RSR 555 wrote:I was just thinking, why not just use L.Series adjustable shocks?
I would have some secondhand onesYarran wrote:Frog had a new pair of OEM struts and I couldn't find any L series ones at the time.. You have a spare set RSR 555?
