WANTED 84 touring edition dash
Posted: Thu Mar 27, 2014 8:10 pm
by calamity
hey all im after a dash board for my 84 touring edition wagon...
either analogue or digital...id prefer digital dash to keep it stock but am needing a dashboard to make the car road legal again...as wont pass pits without a dahs :/
im in tasmania...but happy to pay postage
Posted: Thu Mar 27, 2014 9:18 pm
by suba2
I can supply you with a normal dash $70 posted to yazzie
Thanks Greg
Posted: Thu Mar 27, 2014 9:26 pm
by calamity
by normal dash you mean the analog or the digital? do you have a photo?
Posted: Fri Mar 28, 2014 9:42 am
by suba2
It's a analog will send a pic tommorrow
Thanks Greg
Posted: Fri Mar 28, 2014 11:50 am
by calamity
no probs im putting in new carpet and reupholstering the seats...so im in no rush :)
Posted: Fri Mar 28, 2014 12:23 pm
by Proton mouse
If its a standard Brumby dash, it wont fit. Not without changing your dash pad, shroud above the steering column (bit that has the lights and wiper switches attached to it) and the dash wiring harness.
If its an analogue sports dash (as below) you wont have to change the dash pad, but you will need the wiring harness (all unplugs easily) plus the oil pressure sender unit (on front of motor).
The starwars/digi dashes like you have, are very hard to find in working order and are prone to failure. Best bet is the Tacho/sports dash, which you can source from a '82-'84 sedan orcoupe or '82 touring wagon, although if it is not from the wagon, you wont have the '4wd' or 'lo' indication lighting on the dash.
Hope this helps,
John.
Posted: Fri Mar 28, 2014 10:44 pm
by calamity
thank you this helps out alot im a bit new to cars to be honest...spend most of my life worknig on motorbikes i actually originally only bought this car to transport bikes with and get off road and have abit of fun in it...but iv grown to love it and have since started replacing the carpeting and reupholstering the entire interior...the dash you put a picture of looks like an exact analogue version of the digital one in mine now...
dont suppose you know anyone who has one sitting around they want to sell? :P
Posted: Thu Apr 24, 2014 10:45 am
by RSR 555
Did you get hold of one?
Posted: Sat Apr 26, 2014 9:55 am
by Cliff R
I have bought one before after an enquiry through "Findapart".
Mine is analogue so this is what I ended up with.
Warning - I didn't stipulate I wanted a dash from a 4WD so what I ended up with was a dash that was probably out of a 2WD coupe or the like.
This means the dash didn't have the 4WD shift lights.
I also in future would state I wanted 4WD and a manual to get the lighting indicators right.
