Post
by Matt » Mon Mar 03, 2014 7:23 pm
steptoe wrote:I finally got around to trying a tip from a farmer in here pre 2005 site crash, and that was to hook up a heater hose via 16mm to 12.7mm brass adaptors and run coolant through an A.C. condensor. Is brilliant except for sustained highway driving when heat soak loses its effect, otherwise driving not even switched on an aux fan except extreme cases for short while.
Was considering a crappy bonnet and mount same on flexy heater hoses to bonnet, fan underneath if it fitted - Hummer style
Out of interest what does the car do with extended highway use?
Unfortanately both my cars have condensers in use, one for air con, one for the WAIC system.
'86 Brumby - Dual Port Heads, 5 Speed Dual Range, Custom Cam, Tuned Weber, Tuned Suspension, 2" Body Lift Kit, LSD, 14" rims, 2.25" Exhaust, Snorkel, Dual Batteries, DVD Player, UHF, VHF, etc.
Offically now part of the 350, 000 km Club!
"Claudia"
