EA82 Flywheel and clutch
I'm looking for a Flywheel and clutch to suit my EA82 and any associated bolts etc. I want to do a compression test etc on the motor i have sitting here.
Im located in Ipswich but will travel anywhere in SE QLD..
I thought the ring gear was on the torque convertor?steptoe wrote:You want it just to do a comp test ? No need for a clutch then, just an auto flex plate is all you need to turn donk over , bit lighter on your wallet postage wise.
