92 Brumby Heater tap
Posted: Mon Feb 17, 2014 12:40 pm
by badga880
Hi I am after a heater tap that is for a 92 brumby EA81 it is in the engine bay not to far from fire wall passengers side has 2 pipes going in 2 pipes going to heater and a tap contoler operated by wire from heater knob in dash hope that description helps or that heater thingywith the wire stuff with 4 pie thingys going through the wall...Ok I am in desparate need any suggestion on finding one thanks also need new windscreen rubber to put screen back in and does anyone know if there is a carpet available for a brumby thanks again
Posted: Mon Feb 17, 2014 12:48 pm
by 1983wagon
Got my windscreen rubber new from eBay for around $100 if that's what your after
Posted: Mon Feb 17, 2014 5:44 pm
Yep windscreen rubber as above - fit the trim before you put the screen back in the vehicle ;)
The heater tap, you can substitute a commodore unit in there, there's a thread about that on here somewhere.
Carpet is available - I got carpet for Sunnie the Brumby for about $130 - had to cut my own holes but it turned out well. Also search for MY wagon too as the wagon, sedan and coupe carpets will fit the brumby ;)
Posted: Mon Feb 17, 2014 7:28 pm
by RSR 555
I concur with the above :)
Carpet from any MY Series Touring Wagon, Sedan or Coupe will fit, just need to cut down the rear section a bit. Standard (low roof) MY wagons and MY Brumby had vinyl flooring.
I too have to replace the heater tap and found the commodore one is the closest to the Subie one but from memory, it's vacuum operated, so need to find that thread Bennie has mentioned.
Posted: Mon Feb 17, 2014 7:34 pm
by Silverbullet
http://www.all-car-carpets.com.au/page/ ... 984/_WAGON
For the carpet but have to cut your own holes, use the old vinyl as a template.
Posted: Tue Feb 18, 2014 5:39 am
by badga880
Thanks for that info I will take note about fitting chrome strips first (have to find 1 more corner) and will sort out commodore heater tap and will chase carpet now wonder if they do Purple shagg carpet lol thanks again
Posted: Tue Feb 18, 2014 6:41 am
The Commodore one .... wide choice of years to start with 1978 -9 to 2016 models ..any hint of the model the heater tap is for to fit MY ?
Posted: Tue Feb 18, 2014 10:11 am
by badga880
I just looked on flea bay seen a pic of what was similiar to mine 2 pipes in 2 pipes out in s bend shape did not take any notide of year or model...
Posted: Tue Feb 25, 2014 9:54 pm
Found a VX Commode in the workshop getting anew heater tap and can see it may fit the Brumby/MY's
Packaged by Dayco, is a vac operated unit not a cable - DHV5631 or bar code 9325361315237
Posted: Wed Feb 26, 2014 12:11 am
by RSR 555
steptoe wrote:Packaged by Dayco, is a vac operated unit not a cable - DHV5631 or bar code 9325361315237
Yep.. was pretty sure it was vacuum controlled, so would still like to find that thread Bennie mentioned
Posted: Wed Feb 26, 2014 5:19 am
by badga880
yes still trying to get my head around making the vacuum work by cable
Posted: Wed Feb 26, 2014 9:59 pm
badga880 wrote:yes still trying to get my head around making the vacuum work by cable
When you get it sorted be sure to start a new thread on how to do it ;)
Posted: Thu Feb 19, 2015 8:22 pm
and so this thread ended there....until Jonno finds self cooking internally coz the heater tap is stuck open, unable to be forced closed even ......new from Japan if still available are about the 150 mark, or the Commode one mentioned above by Dayco $20
The Sube parts manual says it is a three port cock - mine has four ports, so to the vac op Commode heater tap. I am think if i ....geebers, did I chuck out a vacuum seesaw switch ??? the kind from the circ fresh switch buttons ???. Reckon one of them mounted in the side of the console will do the job noicely
maybe I can get away witha dissembly and squirt of sheep grease inside to fix ??
Posted: Fri Feb 20, 2015 10:30 pm
after ripping the hoses off the heater tap, I finds the cable was the problem :oops: so cleaned the heater tap up, lubed its bits, shoved it back in, zip tie to reinforce the cable holder, snapped its little rubber jacket back on ...now it is like i have AC !! Fresh cool outside air - goodbye sauna !
Posted: Wed Mar 04, 2015 9:42 pm
^ Gold Jonno!
I've pulled the old tap from our VT when it let go a few months back. I can see how it could be used in the MYs with some mods. Seems easy enough. I've not had to do it yet, but if it comes to it this will be the first stop for replacement ideas...
