Hi
I'm after a steering knuckle for my Brumby; the type with the rubber damper in the middle. Or even just the longer bit off the knuckle (the universal joint).
I'm fitting a 2" lift and the option recommended by Toonga seems to be the most straight forward.
Wanted: Steering knuckle for Brumby
- hairybrumby
If you want the ones with the rubber in the middle I believe they only came on power steering fitted cars. No Brumby came factory fitted with power steering so you may want to ask for MY Leone P/S knuckles. I can give you a manual steering knuckle like the one you have now...
If you bought a complete P/S setup it would come with one for free and make the car steer way better...
- Rhys
91 Brumby
91 Brumby
