Want Urgent: In tank fuel pump assembly for Gen 3 Outback, Perth
Davidov
Post by Davidov » Fri Apr 13, 2012 11:00 am
Hi, Urgently need the Assembly for the fuel pump (also holds fuel filter) in tank for the Gen 3 subaru outback.
The outlet on mine broke off when trying to connect the fuel line back on (crappy plastic was old and brittle :mad:). Put my car out of action.
Im not sure if the actual fuel pump is transferrable between assemblies, but i assume so. If so im just after the assembly no pump or filter or anything.
Cheers.
Return to “Wanted”
