Ej20 turbo Throttle body
Im after an ej20 turbo throttle body. Anyone got one kicking about.
Dave
Dave
- Outback bloke
I don't know if you know this or not but there is different internal bore sizes on them. If you want the biggest you need to get one off a 96-97 GTB manual or similar STi vintage. The throttle pick up is on a different side to the earlier ones.
Even with the earlier single turbo there is a slight difference in size between auto and manual.
Thanks, i didn't know that... im not after a bigger size one though. Im after one to bolt to the ej22 because the factory throttle body is too long to fit my intercooler behind it. I think the Ej turbo ones are shorter. Same bore size as an ej22 would suit me fine.
Dave
Dave
Maybe you could suggest the best one for me.... sorta would like the shotest available that maybe the Ej22 throttle position sensor can bolt too. (if not i might be able to rewire the turbo one in) Also with bore size i don't think it will make too much difference for my application although if it is slightly smaller or larger than the intercooler outlet i may be able to gain some spacce by making them overhang (if that makes sence).
Also am i on the right track thinking the EJ turbo throttle body will bolt to the NA ej22 manifold?
Dave
Dave
i have one at home dave if you wanna test it out?
cheers
cheers
Hunter S. Thompson
Hunter S. Thompson
I found a guy selling one in Perth (Karrinyup). RS turbo EJ20G one, no TPS. He wants $50.
I have been onformed today that the turbo throttle bodies on EJs older than 1999 are about the same size as the NA ones. So looks like i need a newer type.... worst case my best mate Vidler can build me one maybe.
What year car is yours of bren? And by your post it sounds like u don't actually want to sell it.
Thanks heaps for that Andrew... any idea on year model?
Dave
Dave
its from a gc8 MY00
Hunter S. Thompson
Hunter S. Thompson
The RS one would be between 89 and 94 so no good by the sounds of it.
Brenny that might be what i need... any pics?
Dave
Dave
no pix sorry.
Hunter S. Thompson
Hunter S. Thompson
