(WA) WTB: ej22 motor and conversion bits.
ITS TIME.
im looking for either a wreck or motor/loom/ecu of an ej22. around the 200,000km mark. In WA only pls.
also if anyone has a cheap enough modded ea flywheel/radiator/adaptor plate speak up.
matt
matt
Matt definitely pick up a car at Pickles hey, best value way to do it.
Otherwise I know a guy who has a good EJ22 (or at least did a few weeks ago).
I can knock up the adaptor plate and flywheel for ya, I can do them fairly quick now I rekon.
japparts plus had a whole gen1 awd 5sp wagon for 800buks. all that was missing was the rad.
Hunter S. Thompson
Hunter S. Thompson
trust me i was there. looked the car over. blue 5sp awd wagon 800buks jap parts plus
Hunter S. Thompson
Hunter S. Thompson
yep thats the guy
if you want to have a gander matt im going round there this w/e
Hunter S. Thompson
Hunter S. Thompson
hey im looking for an opinion. mainly about vehicles from pickles auctions.
i did already purchase a lib wreck from pickles but turns out its not conversion worthy. dont really wanna make the same mistake again.
http://www.pickles.com.au/damaged/vehic ... -552059167
this is the vehicle in question that i want. i had a look at it and the rad and particularly thermo fans are busted onto the engine pulleys - do you think that this would harm the engine? oil and air filter looks fresh. the bad thing about the auctions is that you cant start up the engines before hand- only after you win it. and what if it doesnt start at all for whatever reason!
i really cant afford to for this one not to work, if i bought it. seems promising tho. all the other libertys ive looked at have way higher km's and dont seem the best for a swap either.
and how many other people have bought cars from pickles and they turned out fine- engine wise?
Mine was fine (WackyBug's) - had about 250,000kms on it. It's a gamble unfortunately.
I've known that feeling before mate, its not good eh? First thing I did to sort my fix was a quick 4wd in some nearby bushSubafury wrote:hmmm i must be getting desperate. since im not driving at all atm
Take your time in picking a car for the donor, all you can really do is look at the oil and the wiring to make sure nothing is damaged.
Its the same at the pick a part joints, you can't start them til you get the engine home and fitted to the car...
Its all one big game as AndrewT said.
