Want to buy
subarubrumby
Post by subarubrumby » Fri May 06, 2011 12:30 pm
well, so far ive worked it all out to be $2255 for my modified ea81.
: $140 32/36 weber set up.
: $115 for the cam grind
: $120 to shave heads.
: $480 HD clutch fitted.
: $550 for block, pistons and hone to suit. (OS pistons)
: $500 labour for my mechanic to pull apart and put in.
: $350 valve work
and i have a L series tail shaft to run to the L series 5 speed gearbox, that i hope is all good to bolt on ???
Post by Alex » Fri May 06, 2011 12:59 pm
and it will still be bullshit slow.
subarubrumby
Post by subarubrumby » Fri May 06, 2011 1:06 pm
why ? cause its just a ea81 ?
H-top
Post by H-top » Fri May 06, 2011 1:11 pm
Alex wrote:and it will still be bullshit slow.
LMFAO!!!
for that price. an ej22 or maybe ej20G is feasible if you do most of the
work or with help.
and it would be infinately more reliable!
cheers
H-Top
rolling in
Post by steptoe » Fri May 06, 2011 1:54 pm
you will likely want to confirm clutch dimension before you buy to ensure spline count to suit 5 speed box to your flywheel.
You wanna drift this, yet pay to have work done ? Where is the fun ?
Surely some engineer has calculated a power formula required to drift. Does your intended build meet that ?
subarubrumby
Post by subarubrumby » Fri May 06, 2011 2:35 pm
alot of haters on the worked ea81. THIS WOULD BE MY FIRST EJ CONVERSION AND I KNOW NOTHING ABOUT IT !!!!! ILL NEED MORE HELP THEN YOU CAN POKE A STICK AT !! and most probaly will fail it...........
H-top
Post by H-top » Fri May 06, 2011 2:48 pm
Chin up man, there are a large amount of conversions
done by backyarders with minimal exp that have been
very successful.
Just read read read read read.
From what I have seen, it really is not all the difficult
with the right tools and friends.
Where exactly are you located?
And I agree, the fun is in building it and enjoying
what you have made.
H-Top
rolling in
subarubrumby
Post by subarubrumby » Fri May 06, 2011 4:01 pm
yeah thanks man, well i am really mechanically minded and my mate is a diesel fitter, and i was a 2nd year boilermaker and engineer, so i rekon ill have a good crack at it.. just the wiring loom will get me for sure, and i live in brisbane ipswich 4305.
H-top
Post by H-top » Fri May 06, 2011 5:24 pm
easy then mate! There are a few people
here that can do the loom for u.
I live in the city mate.
I'm a second year mechanic.
Need a hand, give us a shout.
always keen to play with toys :)
so EJ it is?
cheers
H-Top
rolling in
subarubrumby
Post by subarubrumby » Fri May 06, 2011 5:26 pm
IT IS OFFICIAL !!!! EJ22 IT ISSSSSSSSS !!!! :) :)
EJ22 motor, loom and ecu, ej22 gearbox and diff ? keep in mind ill be having it rear wheel drive, so cant be a AWD.... what tail shaft shall i run ? or do i have to get a custom 2 piece shaft made up ???
H-top
Post by H-top » Fri May 06, 2011 5:39 pm
Any ej gearbox with centre diff modded.
You can use your standard R160 as it does
not need to match the front as it will be RWD
Standard shaft shortened.
H-Top
rolling in
Post by El_Freddo » Fri May 06, 2011 7:00 pm
But Alex you need to understand that he's building it for a set task... And can't have an engine conversion on his P's.
subarubrumby wrote:IT IS OFFICIAL !!!! EJ22 IT ISSSSSSSSS !!!! :) :)
Well, throw that out the window then...
subarubrumby
Post by subarubrumby » Fri May 06, 2011 7:19 pm
Nope change of plans just going to be a track car not needed for p plates !!! Going for the ej22 conversion :d
H-top
Post by H-top » Fri May 06, 2011 7:24 pm
For the win
H-Top
rolling in
subarubrumby
Post by subarubrumby » Fri May 06, 2011 7:27 pm
yeahh man haha so you rekon stock ea81 diff handle the ej power ??
subarubrumby
Post by subarubrumby » Fri May 06, 2011 7:40 pm
this is my final plan..
EJ22 motor ecu loom.
ej22 gearbox.crossbred conversion kit.
diff off the donor car. ej22 diff,
custom 2 piece tail shaft ??
the ej22 brakes.
L series control arms etc for the camber.
brass button clutch
and WRX coilovers in the front. SOUND GOOOOOOD ? any tips or hints ?
Venom
Post by Venom » Fri May 06, 2011 7:40 pm
It's an R160 diff which is the same as every subaru except the newer STi's, so yes it will.
Venom
Post by Venom » Fri May 06, 2011 7:48 pm
subarubrumby wrote:this is my final plan..
the ej22 brakes.
brass button clutch
EJ22 donor would be cheap. surely one of the most popular backpacker vehicles in Aus, so always a few going cheap and needing to be sold ASAP. Why not go a 99- Libery with the Ej25 SOHC?
Liberty/WRX brakes is best done with a Crossbred conversion kit, it basically lets you bolt in the liberty/wrx suspension and brakes in.
http://www.crossbredperformance.com/
If you're building a track/drift pig then why not go the whole hog and get a WRX halfcut with brakes/gearbox etc. I think half cuts go for around the 2-3 mark? Maybe 4 for an STI. It's almost the same effort as doing all the EJ22 gear but a heap more awesome. Obviously intercooler and hyraulic gearbox adds some complications over an EJ22.
Green_eyed_liberty
Post by Green_eyed_liberty » Fri May 06, 2011 8:06 pm
if you need more hands to help out, im more than happy to travel up and help out.
im building an off-road brumby at the moment. but had an RB Sil-Eighty track pig before the brumby ;-)
subarubrumby
Post by subarubrumby » Fri May 06, 2011 10:39 pm
helping would be so good man, that would be the best, well the next 2 weeks im going to put my ebay goggles on and find me a EJ22, ecu, loom, 5speed gearbox, keep the diff in it ? save the money for the crossbred kit, ej22 brakes and coilovers for the front, WISH ME LUCK ANY ONE HAVE ANY INFO OR THE ABOVE PARTS TO HELP PLEASE DO !!! green eyed liberty once i have all the parts and ready to go, ill try my best to do the conversion and if i get stuck ill give you a tingle ? if thats still okay with you ? thanks gents for all the help, now its time to sell my modified go kart team and start work on the BRUMBY !!
Return to “Wanted”
