Want to buy
- subarubrumby
well, so far ive worked it all out to be $2255 for my modified ea81.
: $140 32/36 weber set up.
: $115 for the cam grind
: $120 to shave heads.
: $480 HD clutch fitted.
: $550 for block, pistons and hone to suit. (OS pistons)
: $500 labour for my mechanic to pull apart and put in.
: $350 valve work
and i have a L series tail shaft to run to the L series 5 speed gearbox, that i hope is all good to bolt on ???
: $350 valve work
- subarubrumby
you will likely want to confirm clutch dimension before you buy to ensure spline count to suit 5 speed box to your flywheel.
You wanna drift this, yet pay to have work done ? Where is the fun ?
Surely some engineer has calculated a power formula required to drift. Does your intended build meet that ?
- subarubrumby
Chin up man, there are a large amount of conversions
done by backyarders with minimal exp that have been
very successful.
Just read read read read read.
From what I have seen, it really is not all the difficult
with the right tools and friends.
Where exactly are you located?
And I agree, the fun is in building it and enjoying
what you have made.
very successful.
what you have made.
- subarubrumby
- subarubrumby
But Alex you need to understand that he's building it for a set task... And can't have an engine conversion on his P's.Alex wrote:and it will still be bullshit slow.
Well, throw that out the window then...subarubrumby wrote:IT IS OFFICIAL !!!! EJ22 IT ISSSSSSSSS !!!!![]()
EJ22 motor, loom and ecu, ej22 gearbox and diff ? keep in mind ill be having it rear wheel drive, so cant be a AWD.... what tail shaft shall i run ? or do i have to get a custom 2 piece shaft made up ???
- subarubrumby
- subarubrumby
- subarubrumby
EJ22 donor would be cheap. surely one of the most popular backpacker vehicles in Aus, so always a few going cheap and needing to be sold ASAP. Why not go a 99- Libery with the Ej25 SOHC?subarubrumby wrote:this is my final plan..
EJ22 motor ecu loom.
ej22 gearbox.crossbred conversion kit.
diff off the donor car. ej22 diff,
custom 2 piece tail shaft ??
the ej22 brakes.
L series control arms etc for the camber.
brass button clutch
and WRX coilovers in the front. SOUND GOOOOOOD ? any tips or hints ?
Liberty/WRX brakes is best done with a Crossbred conversion kit, it basically lets you bolt in the liberty/wrx suspension and brakes in.
http://www.crossbredperformance.com/
If you're building a track/drift pig then why not go the whole hog and get a WRX halfcut with brakes/gearbox etc. I think half cuts go for around the 2-3 mark? Maybe 4 for an STI. It's almost the same effort as doing all the EJ22 gear but a heap more awesome. Obviously intercooler and hyraulic gearbox adds some complications over an EJ22.
- Green_eyed_liberty
- subarubrumby
helping would be so good man, that would be the best, well the next 2 weeks im going to put my ebay goggles on and find me a EJ22, ecu, loom, 5speed gearbox, keep the diff in it ? save the money for the crossbred kit, ej22 brakes and coilovers for the front, WISH ME LUCK ANY ONE HAVE ANY INFO OR THE ABOVE PARTS TO HELP PLEASE DO !!! green eyed liberty once i have all the parts and ready to go, ill try my best to do the conversion and if i get stuck ill give you a tingle ? if thats still okay with you ? thanks gents for all the help, now its time to sell my modified go kart team and start work on the BRUMBY !!
