Item............................... 14 inch 4-nut rims x 6, with rubber, as set or will split
Description...................... 185/70/14. 2 near new 4mm+ tread, 2 used 2mm+, 1 bald spare, 1 brand new spare. 2x 9yo speedy rims, 4x older-than-that similar rims. 2x dunlop, 2x daytona, 1x bridgestone turanza, 1x something.. will check last one again later.
Condition........................... see pics. Rims rusted.
Location .......................... canberra [edit: can deliver in 350km radius]
Price................................ neg. Would have sold them 100ea before the rust fiasco. There's probably $400 in rubber here, and a steal if you're willing to sandblast the rims or use as is. If split, price would depend on condition of the ones you want
Contact ............................ by forum on this thread or pm
i bought 4 of them from waggaClint on here in 2007 for $400 including good rubber, and did about 5000k around nw wa over two weeks in 2007. mostly bitumen in the end. a few hundred k of dirt. so they're still pretty good. they've literally sat in the shed since as I'm disorganized and dreamed of still using them til I parted with my ea81 in 2013
 i also bought two brand new rims and tyres to match at the time in 07.
 i also bought two brand new rims and tyres to match at the time in 07.The tragic part is they weren't sitting on sealed concrete, and I put a laminate board over the top and used it as a shelf. When I finally lifted the board after a few years I found moisture had created a seal between the rubber and laminate, and the rims started rusting. Wish I had before shots but its rhetorical now. Hot tip, store your rims somewhere dry.
Bald on top, new on bottom
'new' speedy rims on left, sunnies other four.
Just some evidence of tyre use
