I am having the MY rear towed away for scrap this week, if anybody can use parts still in it let me know.
Two good stock wheels/tyres (will need to changeover), rear bar, tailgate with usual rust in corners, badges, fuel filler door (black), rear doors (rusty), rear seat and interior (tan colour). Tail-lights are both good.
Will likely be gone by Friday at the latest.
FREE: Rear end parts from 82 MY wagon (VIC)
Backing plates / brakes
As Jonno said
I'd like the rear brakes and even complete subframe and trialling arms if it was possible ?
Can you pm me price etc ?
Any way they could be got to Gerard's place in Sydney ?
Thanks in anticipation !
Giles.
Giles.
Giles, sure I can do that for you. The only problem is the passenger side knuckle has a hole drilled in it just above the factory third hole (furthest to the back) as I was using the rear as a way of mocking up the XT6 hubs setup and was going to use one of the Forester backing plate holes and drill the knuckle instead of the backing plate (in the end, I went with modifying the backing plate as the hole was too close to the edge). And the drivers side backing plate is a bit bent due to having to lever the drum brake off. A bit of percussive maintenance should fix it right up
