Genuine AUDM 1993 Gen 1 Series 2 RS Liberty wagon in 222 Dark Grey Metallic (Charcoal)
296,000kms - engine has usual tappet noise as it is still running RS heads. Doesn't blow smoke or use oil though. Just had engine oil change and timing belt done.
4.44 box and tight 4.44 rear diff from a WRX - low ratio gearset. Just installed this and it drives sweet as. Redid the shifter bushes while I was there and changes real nice. Has a genuine STi clutch in it which is beautiful to use.
Currently running on King Spring coilovers - good street set up - height adjustable only. Can put std springs in if required.
3" Stainless TBE Exhaust - bit bodgy where they have extended it for the wagon but has a nice Ganador muffler.
Everything else is standard including the rims. Interior is very good for its age - only a bit of collapsed padding on drivers seat but no tears or excessive wear. Carpet in drivers footwell has the built in rubber mat missing so looks a bit tacky. Only has a cheap head unit and cheap (but Sony / Pioneer) speakers.
Body work is OK but not great - bumpers have cracked paint, small dent in RHR guard and clear coat peeling on bonnet and roof.
Car is located in Geraldton 400kms north of Perth. Currently has no tyres. So options are :
I will put secondhand 15" tyres on std rims.
You supply rims and tyres.
for an extra $500 I can supply 18" charcoal centred/chrome lipped rims with legal tyres. But these are not available until mid march.
Chasing $3000 for quick sale - includes delivery to Perth.
PM or 0439 949 633 (call only - no text)
Pics to follow
