				Fs Gen1 S1 Liberty Wgn
				Posted: Fri Jun 27, 2008 6:48 pm
				by chriSTIan
				Item..1991 GX liberty wagon awd
Description..white awd manual dual range with working air suspension
Condition..vgc,new timing belt,idlers,seals,water pump,thermostat,coolant,clutch plate,g/box oil,near new tyres,tow bar,remote immobilizer,kenwood cd player.A/c regassed.
Have all receipts.
Rego due next month
Location ..Perth WA
Price..$4000
Contact ..Christian 0419 928 306
Photos soon
				Posted: Sat Jun 28, 2008 10:44 pm
				by chriSTIan
				Posted: Sat Jun 28, 2008 10:54 pm
				by chriSTIan
				engine out
new clutch disc
water pump
idlers
				Posted: Mon Jun 30, 2008 8:28 am
				by chriSTIan
				173000kms,3000kms since belt etc...done
				Posted: Mon Jun 30, 2008 2:06 pm
				by RetroLover
				This vehicle is still an interest to me, AC works all good i guess cause youve re-gased it.
Does that model have the 110kW 2.0 DOHC engine? Im assuming from those pictures cause is see DOHC on the engine.
				Posted: Mon Jun 30, 2008 2:23 pm
				by Wilbur
				Looks like 2.2 sohc to me.
				Posted: Mon Jun 30, 2008 2:24 pm
				by D3V1L
				its a single over head cam motor...double over head cams didnt come out till very late 1990s
				Posted: Mon Jun 30, 2008 2:43 pm
				by RetroLover
				Says 16 Valves on the one of the engine pictures so im guessing that means its DOHC, not a SOHC. I thought 8 valves would mean its SOHC. Im might be wrong.
So the engine would be the 97kW 2.2L SOHC then, yes??
				Posted: Mon Jun 30, 2008 3:15 pm
				by vincentvega
				look at the car its in. Series1 liberty = EJ22
its a boxer engine - SOHC = 2 cams
				Posted: Mon Jun 30, 2008 3:19 pm
				by RetroLover
				So what the power output on that engine variant??
"x"kW @ "x"rpm
"x"Nm @ "x"rpm
Somebody should know these specifications?? I want to do a comparasion with other cars.
				Posted: Mon Jun 30, 2008 3:22 pm
				by AndrewT
				D3V1L wrote:its a single over head cam motor...double over head cams didnt come out till very late 1990s
Except for turbo EJ20G (1989) in RS liberty, early 90's WRX etc but those are only EJ20. Ej22 yeah only much later models in dohc.
Yes common confusion. 2 cams but still only 1 cam per head so sohc.
dohc ones are sometimes called Quadcam engines.
				Posted: Mon Jun 30, 2008 3:45 pm
				by RetroLover
"x"kW @ "x"rpm
"x"Nm @ "x"rpm
				Posted: Mon Jun 30, 2008 7:18 pm
				by Suby Roo
				RetroLover wrote:So what the power output on that engine variant??
"x"kW @ "x"rpm
"x"Nm @ "x"rpm
Im pretty sure the SOHC 2.2 Motor has 100 kW at 6000 rpm.
Not sure on what the torque is on it though
They haul quite nicely and are fuel efficient!
That is a nice looking Liberty Too!! :P
				Posted: Mon Jun 30, 2008 11:47 pm
				by RetroLover
				Heres the information i was looking for. Found it on redbook.
Engine:          EJ22, NA, 2.2L
Power:          100kW @ 6000rpm
Torque:         189Nm @ 4800rpm
Same power as a current model Toyota Corolla, but the Corolla doesnt have that extra 14Nm where you need it most, not at the end of the rev range.
				Posted: Tue Jul 01, 2008 12:03 am
				by Matatak
				your comparing a Gen1 Liberty to a Newage Toyota Corrolla
				Posted: Tue Jul 01, 2008 12:45 am
				by RetroLover
				Matatak wrote:your comparing a Gen1 Liberty to a Newage Toyota Corrolla
Just comparing engine output from late 20th century car engines to that of today. I love the old Subaru's as well as the old AE86 Corolla and all but the new Corollas drive like shit with crappy torsion beam rear suspension and huge A and C pillars where you cant see shit when parking or overtaking. Would be cool if some of those older naturally aspirated Subaru engines just had that little bit more power. Like my old Leone's EA82 it needed more than 72kW of power, i tried everything from running it on 98RON and weight shedding to make that car just a little bit quicker.
				Posted: Sat Jul 05, 2008 3:31 pm
				by chriSTIan
				Bump to the top
				Posted: Sun Jul 06, 2008 2:40 am
				by seagull
				I have a turbo wagon for sale
