Ebay Auctions
- Proton mouse
Proton mouse wrote:If you want a laugh, have a read of this Brumbys description on Ebay..
http://www.ebay.com.au/itm/Subaru-Brumb ... 3a8df3df06
made my day. thanks for sharing!
1978 Brumby on eBay
http://www.ebay.com.au/itm/1978-Subaru- ... 459&_uhb=1
Nice starting price, not so nice cowl rust!
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
- Proton mouse
My pleasure, glad you enjoyed!!ozdog wrote::p:p
Stumbled upon this black alloy (factory??) MY bull bar on gumtree in Brisbane.
http://www.gumtree.com.au/s-ad/bracken- ... 1041087423
- Willy Fisterbottom
- Proton mouse
Complete set of Brumby chrome trim in Victoria. Wont post but maybe courier?
http://www.ebay.com.au/itm/SUBARU-BRUMB ... 1269393814
This looks like a bit of fun.
http://www.ebay.com.au/itm/Subaru-L-Ser ... 316wt_1362
L serious, still.
- Tweety
Full SPFI injection system for ea81 minus manifold. 2 days to go.
http://www.ebay.com.au/itm/221410797159 ... 1555.l2649
Damn you Tweety! Why does stuff like this always come up when you can least afford it!?!?Tweety wrote:Full SPFI injection system for ea81 minus manifold. 2 days to go.
Oh well, good luck with the sale.
Old Boxer Tricks
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
- Silverbullet
What manifold were you using? I am keen.Tweety wrote:Full SPFI injection system for ea81 minus manifold. 2 days to go.
- Tweety
I'm using the sPFI manifold for my weber 38/38 project on my rebuild engine. larger carbie think best to use the largest manifold and with a port would give nice breathing.
So the SPFI unit is otherwise complete. shouldnt cost too much for a bare manifold to be shipped from the US.
The system has all wires tagged so is easy to fit for that reason. I highky suspect I had internal issues with my ea81 that led to the engine failing. Naught to do with the SPFI system. I used 2 litres of oil in around 50kms. I just havent got the patience to keep the system.
It was advertised on here some time ago ...
Any chance of posting a pic of the SPFI manifold next to a carb manifold so I know what I'm up for in regards to modifications?Tweety wrote:I'm using the sPFI manifold for my weber 38/38 project on my rebuild engine. larger carbie think best to use the largest manifold and with a port would give nice breathing.
Cheers.
- Tweety
The last pic is of a black bolt rHS for the temp sensor that has been plugged and a brass sensor that is my reversing alarm from a truck that sounds when my radiator coolant reaches 95 degrees C (the perils of a rear engined trike).
The SPFI manifold shown has its intake hole enlarged. from bolt to bolt (centres) 80mm and bolt centre to bolt centre direction along the manifold 70mm. hope this helps.
What is important here is sensors. They can cost a fair bit to replace. In desperation several were replaced. There are 3 throttle position sensors all good, the temp sensor was tested and is fine, the MAF was faulty and replaced. And I have a separate MAF off another car with the same part number for some experimenting if you please. The MAF part number is shared with I think a Nissan Navara (US) but isnt the same. There is a spare injector that has been swapped and works as welll as the original I had- these cost big dollars. ECU works great. Fuel pump (HP) is near new. Coil is fine and there is a spare coil mount. This mount has a spare transister on it, these can fail apparently.
- Tweety
Item didnt sell.
Is automatically readvertised another two times. So about the start of May it will cease to be advertised and will gather dust until one of you young guys gets that microsoft job and wants to buy it. lol
