Gearboxes for sale
Gearboxes for sale
Hi , i have a couple of gearboxes i no longer need.
1. L Series AWD center diff lock gearbox with EJ front cases so will bolt straight to your EJ. Comes with a modified gearbox crossmember and tailshaft to suit a Gen 3 Outback. G/C. $650.00
2. Version 2 WRX STi Gearbox 4.11
G/C $450.00. Can supply code if required.
Pick up near Gatton, Queensland or i can drop off in Brisbane .
I can be contacted here or phone 0413134382
Jeff
Jeff
They are hard to come by. I bought mine years ago for $450. Problem is, MY and L series stuff is getting old and a lot of the enthusiasts have moved on or they are on serious budgets. I'm surprised you haven't had an offer. Sorry I'm not looking to buy, but good luck with it!
EDIT: Oh and you probably would have more luck if you put the centre diff lock text in the title of the listing.
The centre diff lock isn't that hard, the 4wd Vortexes had them, its the dual range bit that's rare. If you had one of those to suit an EA82, then I'd be knocking at your door... :P
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Previous rides:
How is the low range activated?
Rod through the rear casing like the L series, or cable directly to the low range pivot on the side of the case?
I currently have a single range with centre diff lock from a Vortex in my car, but with the black RX turbo interior (which was only dual range), the centre console looks like it's missing something.
Current rides:
Previous rides:
Previous rides:
The locking centre diff casings didn't have the rods through them.
The dual range AWD locking boxes did. The single range didn't need it as there was no need.Phizinza wrote:The locking centre diff casings didn't have the rods through them.
If you've got a dual range L AWD box and no rods through the back of the box you've got one that's either been converted or had the centre diff and housing replaced with one from a single range box.
I currently have a single range, centre diff lock box in my car. Would you be interested in doing some kind of trade for the rear casing that has the provision for the low range rod?
I'll be in Brissie this weekend & heading to Toowoomba on Sunday. Could I schedule to meet you & have a look?
Current rides:
Previous rides:
Previous rides:
