in my first swap i just used a efi tank and small metal pipe section that goes over the rear sub frame. i used the normal carby lines after that peice. works fineDann wrote:yeah I see what you mean about the fuel tank tony :S ... mmmm
yeah mabey not then mud_king91.
Finding it abit hard to get one with the lines in Perth at the moment though.
dirt cheap touring wagon parts
mud_king91 yeah that sound good hopefully we can mabey work something out
, and shuffbag yeah it's mainly the tank that I need but the lines are too.
Dann
Looking for:
- LSD diff
						Dann
Looking for:
- LSD diff
Sorry, that picture wasn't of an L series item, I was just using it to identify the part Im after, the shaft that joins the steering shaft to the steering rack with a uni-joint on each end.mud_king91 wrote:My knuckle looks nothing like that
If it come from an L series with power steering, it should fit, but can you send me a picture, just to be sure?
Did you end up finding a dead ECU case?
- mud_king91
I found the back of it i cant find the casing or top cover and yea ill get a pic once i get homeGannon wrote:Sorry, that picture wasn't of an L series item, I was just using it to identify the part Im after, the shaft that joins the steering shaft to the steering rack with a uni-joint on each end.
Back cover is fine, as long as it has the mounting holes that attach to the steering column
