in-car fishing rod carrier
All things related to help you get the Catch of the day ...
lefty
Post by lefty » Fri Aug 20, 2010 3:11 pm
has anyone made their own in-car fishing rod carriers?
just looking for ideas, came across this one but not really to my liking
Not interested in roof rack carriers
Post by Alex » Fri Aug 20, 2010 3:45 pm
yeah seen ones like pictured before. Also seen wooden brackets botled to the roof to work in the same way as the ones in the pictures.
Post by El_Freddo » Fri Aug 27, 2010 7:48 pm
Its all fun until someone gets a hook in the eye!
Ok idea I guess if you're careful
longy99gt
Post by longy99gt » Fri Aug 27, 2010 8:24 pm
good luck phil!
"SUUBMARINE"
20" LED Front Light Bar
lefty
Post by lefty » Sat Aug 28, 2010 12:13 am
found this one from the USA but it costs US$120 plus $60 shipping
stuff that I'm going to DIY something similar
MY05 Forester XT
Post by El_Freddo » Wed Sep 01, 2010 2:12 pm
lefty wrote:found this one from the USA but it costs US$120 plus $60 shipping
Looks pretty neat!
Why not do something like the first one but use some conduit the same size to slide the rods into - this way the rods are safely contained in the conduit and no hooks are allowed to fall out and create a problem.
Space will be the issue on this one I reckon... Just sharing thoughts, it'd be cheaper than the $180.00 anyway.
lovey80
Post by lovey80 » Thu Sep 02, 2010 4:18 am
The conduit would be a great Idea but would not allow the reels to be kept on the rod. The whole point of having a system like this is so you can rig up your rods the night before and load them in the car where they wont get broken and you wont catch yourself on hooks.......... Conduit pipes are good if stored with the rod only but when you have the reel on the weight is put onto the runners which isn't a good thing.
Chris
Post by El_Freddo » Thu Sep 02, 2010 10:20 pm
lovey80 wrote:The conduit would be a great Idea but would not allow the reels to be kept on the rod.
Yes it would. All you do is cut a groove for the support arm of the reel to slot into, do this on the top side of the conduit so that the rod slides in and locks into position using this groove. You then use a piece of elastic cord or the like to hold it in place.
The support arms to hold the rods would sit closer to the rear seats to make room for the reels and would probably sit lower from the ceiling of the subi.
A bit of imagination should have this done. I'm now wishing I had have thought about this before I got one of those pedestrian graters that mounts on the front bar - the conduit would protect the rod a pot load more than hanging them in the air does!
lefty
Post by lefty » Thu Nov 18, 2010 9:06 pm
After sending several emails to the US seller and getting zero replies, I had a go at making my own using a telescopic handle,curtain rod, GPS mounts and foam tubing. All up cost around $25. Not as pretty but it does the job!I will also clip the back carrier to the child safety restraints so the rods don't become spears
I can fit a 6"6' rod. I haven't tested how much weight it can handle yet but it feels pretty strong although I won't be carrying my Alvey on it
MY05 Forester XT
hazzard
Post by hazzard » Sun Dec 26, 2010 10:30 am
Love how its held up by gps mounts good thinking
Return to “Fishing”
