Pissed off at Braid...
- Ben
I have been using baitcaster type reels for about 18 years now, I am pretty confident with them and my Abu 6500C3 I can cast all night and day without backlash. I recently got a brand spankers 4600C3 to use for bass fishing and spooled it up with 150 yards (backed with mono) of Penn 8lb (1lb mono equiv) braid to the spool lip. Spooled as per instruction, tight as I could get it to prevent binding etc.
Spool brake is set up to not let the line fall without a small flick of the rod, and then it falls about 20cm or so (my 6500 with mono drops the load to the floor when I let go of the spool) as per the reel instructions (looser makes it cast worse!!) I have tightened it up a bit more, but still want it to be able to cast.
Is braid really as 'super' as the pro's make out to be? Anyone got a fix for me?
The braid was $40 - don't want to have to spend another $20 to get another spool of good mono...
- Outback bloke
I have an Abu 6500C3 that I used to love using with mono on it. I switched to braid a few years back and have hated the real ever since. The braid cost me quite a bit back then and it wasn't until just recently I thought stuff it and took the braid off. It was possible to feel every single thing the lure did. Every touch from fish. Casting was eventually worked out. I just didn't like the stuff. I also believe that I used to get less strikes with the braid. In my opinion it was due to the higher vis of the line.
I went Jack fishing with it a few weeks back and it is again one of my favorite reels now it it is spooled again with 12lb Platinum mono.
Spend the $20. Put the braid on a spin reel, or better still, in the bin.
I have used braid in the surf and can't speak highly enough of it there. Cost is the biggest enemy of braid, especially when you consider how much it would be to spool an Alvey.
- Sti_Brumby
braid is great on spinning outfits, and larger overheads such as TLD's etc, but onto smaller reels such as your abu's its pretty average! if you want to use braid on smaller overhead reels use something like fireline, its Gel-spun instead of heatfused(spiderwire etc) it will come of the reel much easier and isnt overly thin like  penn braid and them others!
Even try the new suffix matrix pro braid(really good stuff)
- FISH_Stalker
