Timing Belt in Camry, Who has done one?
Post by Gannon » Tue Aug 22, 2006 4:52 pm
My girlfriend has a 92 Twin cam 2L Camry and has just clicked onto 300K
I think its about time the timing belt was changed, the sticker that shows when it was last changed has faded and cant be read.:confused:
Now, I figure that it shouldnt be too hard. I just have to be careful to make sure that the timing is spot on first time.
Anybody got any tips and tricks for me?
Many thanks in Advance :cool:
stamp_licker
Post by stamp_licker » Tue Aug 22, 2006 7:46 pm
its a pita.when i had mine got 3/4 of the way thru it and call a mobile mechnic to finish the job i had stripped the teeth of the belt left it to long.Subes are way easier.
Building a hardcore postie:D
chubby37
Post by chubby37 » Tue Aug 22, 2006 8:53 pm
i have done it before and yes it is a pain...motor must come out to do it right but thats just the start of the fun
Post by Gannon » Tue Aug 22, 2006 9:14 pm
Thanks guys
So it really is that hard? :(
A quick chat to a guy from tafe that used to work for a toyota dealer said just to undo the drivers side engine mount and jack the engine up one side. that gives better access.
What were some of the problems that you encountered?
Is it worth doing it myself, or should i save myself the hassle and just pay somebody to do it.
Your right postie,.. subes are easy, ive had the belts off mine twice this week to get to the oil pump (damn ticky lifters)
chubby37
Post by chubby37 » Tue Aug 22, 2006 9:19 pm
after the one i did i would pay someone to do it....if it,s your first time...there is just no room to see or do anything and the crank pully needs to come off and on a camry that can be a nightmare itself...i guess if you take your time and double check everything you should be right but i would never do another one
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Aug 22, 2006 11:07 pm
To do it successfully you need to drop the motor out. Its a prick of a Job
The long road ahead
waggaclint
Post by waggaclint » Tue Aug 22, 2006 11:27 pm
you dont need to drop motor out ive done heaps of them..pull the engine mount out as your friend told you.... take the alternator off as well and undo the power steering resivour and move it to the side then you can get in there... Warning some of the bolts are hard to get at and double check your timing marks..Wind the motor over a few times by hand when the new belt is on and recheck the marks line up... check your water pump to hey there usually start leaking after a new belt has been put on....
2011 Forester X
Subyroo
Post by Subyroo » Wed Aug 23, 2006 11:34 am
Leave it to the experts I say, if something fails or goes wrong they pay not you..........can't go past warranty work, that's if Toyota give a Warranty on their service work.
I tried mine on a VL Commodore a few yrs back and they are easy to get too, ended up getting the Mechanic from work to finish it as I had misread the way they count the teeth on the belt and it was out of whack PITBA.
Peter
stamp_licker
Post by stamp_licker » Wed Aug 23, 2006 3:36 pm
the drop engine jack up method does work my mate has done it a few times still a pita.
Post by Gannon » Wed Aug 23, 2006 7:33 pm
Thanks for the replies guys
I had a talk to the guy today, he said he used to do them in a little over an hour. I dunno about that.
He told me that it would be easy, but now i dont know what to think.
He also suggested i change the crank and oil pump seals while im at it.
I will have another look at it tomorro and make a decision.
Cheers fellas
waggaclint
Post by waggaclint » Thu Aug 24, 2006 8:57 pm
just buy atiming belt kit they come with all the seals and new idler pulleyes as well..i can do them in an hour but ive done a fair few and im a mechanic so ive had a lot practice...have a go at it if all else fails get a mechanic to fix it...
2011 Forester X
MUDRAT
Post by MUDRAT » Thu Aug 24, 2006 9:16 pm
Join NRMA Plus two days before you try the job. :-)
waggaclint
Post by waggaclint » Thu Aug 24, 2006 11:25 pm
lol could be good idea...
2011 Forester X
Post by Gannon » Sat Aug 26, 2006 2:54 pm
Thanks
Im gonna try it. It shouldnt be that hard.
Expect to see a help post from me if i have trouble
SubyDreams
Post by SubyDreams » Sun Aug 27, 2006 9:57 am
I don't know how to change a timing belt but my camry is for sale if anyone wants to buy it for their kids before they let them loose in a suby! :D
