99 cent super soaker sponge. uses ??
bought this sponge under impulse buy.
It came in a sealed platic wrapper aleady moist !! All the way from China too
About the size of a sharpening stone
It has got me why a sponge has to be sold in a wet state ?
No printed suggestions for use, just a graphic of a car and dash gauges.
It is a very closed cell sort of foam so no good for washing paintwork
I thought I'd used it to absorb the water leaks from my specialist installed windscreen some time back, (shoved under the dash somewhere) but have since fixed that problem when I installed my latest screen.
anyone got these
suggested uses ?
anyone got these
suggested uses ?
- Suby Wan Kenobi
- tim_81coupe
err, it'll crumble and go into the engine ?stinky wrote:air filter element. spray it with k&n oil and voila!
best stuff for ad-hoc air-filter is that bubble foam stuff you get some times in packaging for PC mbs, or other electronic stuff..its usually black/grey.....works well as a prefilter to grab the main dirt too.
- Suby Wan Kenobi
- tim_81coupe
photo ?
no
never thought of that
been to Clints or the whorehouse lately ?
thats where I got it
picture this
rectangular block, 33mm high, 170mm long, 75mm wide, pale yellow, has about the sponginess of a marshmallow, wrapped in its wet state it weighs 96 grams. The moisture disappears from the bag into the sponge and vice versa (temp dependent) so maybe a rough thermometer !
time to charge up camera for a photo shoot
no
picture this
- Suby Wan Kenobi
First, you should cut the sponge into four pieces.
When you re-assemble your EA82t you should leave a piece of the sponge in each combustion chamber, so next time you crack a head the sponge will just absorb the water and you can keep on driving.
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry
Nut this one out
The sponge takes up less than half a cubic litre of space, already moist in its packaging, opened and placed in 500 mls water it soaked up 400ml! and gained only an extra mm or two in each direction.
Now fully soaked it really looks in place on a cheeseboard with crackers and cheeseknife !
Pick the sponge up gently and water remains suspended in it and no drain out.
Where is Deane Hutton or Dr Karl when you need them ?
