Unfortunately, 2 of the biggest issues were in the middle of the roof and I now have a problem with warping of the roof.
I see from looking on the net there are things called shrinking discs which attach to a grinder. Not sure how they work yet but the principle is the unit heats the area that is raised and when hot the area is cooled which shrinks things back down.
I guess I am lucky in that the areas in question are over one of the roof channels so I can adjust these a little with packing low points and running internal longitudinal struts down the roof to stop other areas popping back in or out, (ie, I can pop the panels back out so they look pretty straight but one push and they pop back in again) but it would be more practical to try to shrink the roof panel back in. I don't have access to oxy or the like. LPG maybe (I do have this) ?
Anyone had any experience with car metal warping and what did they do about it.
I have the roof liner out so have access to the underside of the roof but not directly under the warped area (downside I guess) where the roof channel runs.
