Need Advice on Battery Impact Wreches
Posted: Sat Jan 01, 2011 7:52 am
G'day fellas,
I am in market looking for stronger impact wrenches - I don't know which to get and I'm hoping someone out there could tell me..
At the moment I have this Makita BTD140 with 160nm of Torque
which has 160nm of torque, It can undo wheel nuts since they're around 110nm, but I've noticed there is some bolts that it cannot undo ie. bolts on gearbox is tighter that the impact wrench above cannot undo, I can undo by hand but the impact cant.
So I am looking at one of these two below -
Makita BTW251 which has 230nm of torque
Makita BTW450 which has 440nm
My question is - if i bought Makita BTW450 will I need anything more than 230nm? or get 230nm model which is "plenty"? (I dont want to buy 440nm that, If dont need more than 230nm)
The only thing I don't like the BTW450 is pretty big and looks heavy but I haven't been to the shop to see how heavy it is, also i don't want something too "big" for areas where it is tight access ie. to undo bolts on engine-gearbox while in car etc..
It has be Makita due batteries that I have here, don't really want to buy different charger & battery etc. I do have air impact wrench but its a PITA to start up compressor, get the hose and the hose has to follow you around etc - makes me scream!
Will be used for everyday use for work and home use etc.
Thanks
Thanks
