Found some dusty stuff
Posted: Fri Sep 03, 2010 3:55 pm
by FROG
Ive uncovered a veritable stash of bits and pieces :D
listed here by part number open to reasonable offers on all items
there is more(so much more) so if your looking for something rare or hard to find grab a vin number and throw me a pm
062440528 seal 1
623024020 centre piece hub 1
633124170 bush gearshift 2
682115501 combi switch 1
721037010 tie rod end boot 1
721047270 stab bush 1
721342110 stab bush 1
723236000 axle nut 2
731320010 lh tie rod end 1
733229010 bush gearshift 2
741022070 mount brumby 1
745153011 rad cap 1
762222160 holder 1
791017200 clip 3
803920010 spw 1
806727030 oil seal 1
806738040 oil seal 2
806738040 oil seal 1
806935010 o ring 1
807907282 hose water 1
809221100 v belt 6pk1640 1
902350006 nut 2
905920026 rivit 6
906010019 bearing 1
906250018 seal 1
909130062 clip 4
909130105 clip 2
11044aa483 head gasket 1
13270aa050 rocker gasket 1
13272aa050 rocker gasket 1
13293aa001 spark gaskets 2
15208ka010 oil filter 1
16546aa080 air filter 1
20493ag010 kit stab bar 1
20550aa010 nut 1
20560aa011 washer toe adjust 1
21204aa711 hose 1
22315aa021 vac connector 1
22401aa580 spark plug 1
22401aa630 spark plug 1
23222ga153 cv boot frnt 4wd 1
253212b000 rad cover 1
26061ag000 cover sunroof rh 2
26297aa020 seal kit 1
26296aa163 brake pads 1
28015aa050 oil seal 1
28419fe011 housing rear axle lh 1
28023aa044 cv boot frnt 2wd lib 1
28423fe050 cv boot 1
30531aa132 lever clutch 1
32018aa002 low switch 1
32615aa002 synchro spring 2
41021ac170 cross member 1
42025ae000 fuel pump gskt 1
42060aa040 fuel pump gasket 1
42072ga061 fuel filter 1
42072ka020 fuel filter 1
44165ag000 gasket 1
45122ga121 fan blade 1
45122ga160 fan blade 1
45124aa000 air plug 1
45161ae060 hose 1
45167fc000 hose 1
456137fa002 shroud 1
492105602 switch magnetic 1
50812aa010 stay hood lock vert 1
51551fe040 rh inner lower panel 1
51551fe050 lh inner lower panel 1
53010sa0609p lh hl panel 1
53060ag0009p upper frame 1
53060sa0409p top lock 1
56410ag140 engine under cover 1
56410ag141 engine under cover 1
57150ae020 lh headlight bracket 1
57260fa000 rh bonnet hinge 1
57260fa010 lh bonnet hinge 1
57330aa010 trunk cable 1
57430fa021 key 1
57531ag000 trunk striker 1
57707ag031 lh bar bracket 1
57707ag080 lower centre bracket 1
57707fg050 front bar lower bracket 1
57711fg0109p rr bar reo my10 forester 1
57719aa001 screw front bar 3
57730ac040 bar cover 1
57731fe320ga rh fog cover 1
57744fa230mh lh fog cover 1
59110fa010 lh splash 1
62240fe070 sash window 1
63269 fe 210 stay assy kit 1
63511ag000 weatherstrip 1
63521fe030 weatherstrip lh 1
64619fa501mu seat belt 1
64662ag100jc seat belt 1
64780ac500vb belt stopper 1
65021ac080 seal 1
65023ac000 screen mould upper 1
65023ac030 screen mould upper 1
65407ag000 cover 1
65407ag010 cover sunroof lh 1
65409ag000 repair rod sunroof rh 1
65550ae002ml tonneau cover 1
65552ac000mu stopper 1
72411fe001 heater hose 1
73741fe001 belt cover 1
760102330 door stopper 1
81890fa050 bracket 1
83001fa100 switch fog lamp 1
83071ae071 power window switch 1
83191ae000 ignition switch 1
83370aa001 stop lamp switch 1
84001ac051 lh headlight assy 1
84001fa260 lh headlight assy 1
84401ac020 lh repeater lamp 1
84701ag001 hi mount lamp 1
84927ac120 rh fog light bracket 1
84927fa001 rh fog light bracket 1
84953fc040 rh fog cover 1
84501fe080 fog assy 1
86301fe180 tweeter 1
86301fe190 tweeter 1
86548pa000 wiper blade 1
90810pa010 clip 5
91017fa010 clip 1
91057fc220 rh frnt side garnish 1
91057fc230 lh frnt side garnish 1
91059fc010 rivit 1
91121ag010 grille (badge bad) 1
91131ac000 protector whl arch 1
91141sa010 cover 1
91572fe040 awd decal 1
92114ag011jc console lid 1
92122fe010oe gear lever cover 1
93033fe020 badge rear 1
94061ae030 sill cover 1
94220ae481ml trim panel assy rh 1
94269ae001ml arm rest rh 1
g3210fc100 pollen filter 2
j1010ae124 rear mudflaps 1
j101aag250 fog covers 1
j1010ae131 mudflap 1
j1010fe361 front mudflaps 1
j501sfg300jh cargo tray 1
sa1122002 clamp kit re fit 1
sa613 headlight protectors 4
sa931 rear muds 1
sap1122 oil cooler kit 1
Posted: Fri Sep 03, 2010 7:26 pm
by FREEDOM
Thats alot of stuff...
Posted: Sat Sep 04, 2010 8:59 am
by chridk
If you find any crome tray trims for a 92 brumby that are covered in dust instead of dints I'll put my hand up.
I know this is probably a stupid question but I had to ask.
Cheers Chridk
Posted: Sat Sep 04, 2010 9:55 am
by FROG
chridk wrote:If you find any crome tray trims for a 92 brumby that are covered in dust instead of dints I'll put my hand up.
Cheers Chridk
can only get the tailgate one is about $100
cheers Andy
Posted: Sun Sep 05, 2010 6:44 pm
by Lucky67
I've got a 92 Ag-Quip Brumby, and I notice the various part numbers listed as trim pieces.
In that list would you happen to have the trim black aluminium/rubber pieces that clips along to top of the door skin where the window drops past ?
I am not sure what the correct name would be. I think the workshop manual calls it an outer weatherstrip.
Wayne
Posted: Mon Sep 06, 2010 11:22 am
by FROG
OK guys due to the amount of interest I have started putting up photos in my albums will get around to answering all inquiries as time permits
album.php?albumid=89
Posted: Mon Sep 06, 2010 11:28 am
by FROG
Lucky67 wrote:I've got a 92 Ag-Quip Brumby, and I notice the various part numbers listed as trim pieces.
Wayne
Wayne
re belt mould I dont have one here but there are three in Australia I can get you one for around 120.00 plus freight out to you
cheers Andy
Posted: Mon Sep 06, 2010 12:12 pm
by Subafury
holy crap! thats a lot of parts. would of taken you ages just to write the list. been working for subaru long?! haa
Posted: Mon Sep 06, 2010 3:23 pm
by spike
whats the oil cooler kit for??
ill put my hand up if the price in reasonable
Posted: Mon Sep 06, 2010 4:41 pm
by FROG
spike wrote:whats the oil cooler kit for??
pm sent.............
Posted: Mon Sep 06, 2010 6:49 pm
by FROG
Subafury wrote:holy crap! thats a lot of parts. would of taken you ages just to write the list. been working for subaru long?! haa
that list literally took me seven years to compile :D
and there is so much more :-(
so so much more :rolleyes:
Posted: Tue Sep 07, 2010 1:02 am
by sublime
Sent a PM but I want 682115501 combi switch 1:shock: And anything else you may have for 1970s models for that matter!
Posted: Tue Sep 07, 2010 4:52 pm
by FROG
Found some more :D
targa top Brumby LH targa hinge x 1
targa top Brumby targa hinge(female) x 1
brumby fan knob x 1
brumby hood lock x1
Posted: Tue Sep 07, 2010 4:54 pm
by FROG
sublime wrote:Sent a PM but I want 682115501 combi switch 1:shock: And anything else you may have for 1970s models for that matter!
sold pending payment to the lime sub
Posted: Thu Sep 09, 2010 9:04 am
by FROG
added some more to the add today
bargains to be had
Posted: Wed Aug 10, 2011 6:04 pm
by FROG
Ive dropped the prices on alot of this old stock again, I need the space, if you see something drop me an email or call me and we can negotiate :D this list is by no means complete!
062440528 seal 1 rear inner axle seal Brumby 13.00
623024020 centre piece hub 1 Brumby 22.00
721037010 tie rod end boot 1 Brumby 11.00
721047270 stabilizer bar bush 1 Brumby 8.00
721342110 leading rod bush 1 Brumby 9.00
723236000 axle nut 2 Brumby 11.00 each
741022070 mount brumby 1 70.00
745153011 rad cap 1 Brumby 32.00
806727030 rh rr diff oil seal 1 Brumby 12.00
806738040 oil seal 2 16.00 each
806935010 o ring 1 5.00
807907282 hose water 1 24.00
809221100 v belt 6pk1640 1 58.00
902350006 nut 2 3.50 each
905920026 rivit 6 1.80 each
906010019 bearing 1 pwr stg Brumby 32.00
906250018 seal 1 14.00
909130062 clip 4 4.00 each
909130105 clip 2 2.00 each
15208ka010 oil filter 1 FIORI 10.00
20493ag010 kit stab bar 1 13.00
20550aa010 nut 1 10.00
20560aa011 washer toe adjust 1 2.00
21204aa711 hose 1 30.00
22315aa021 vac connector 1 4.00
23222ga153 cv boot frnt 4wd 1 45
253212b000 rad cover 1 25.00
26061ag000 cover sunroof rh 2 15.00
26297aa020 seal kit 1 70.00
26296aa163 brake pads 1 90-96 liberty front 175.00
28015aa050 oil seal 1 23.00
28023aa044 cv boot frnt 2wd lib 1 43.00
28423fe050 cv boot 1 62.00
30531aa132 lever clutch 1 52.00
32018aa002 low switch 1 48.00
32615aa002 synchro spring 2 2.00each
41021ac170 cross member 1 200.00
42025ae000 fuel pump gskt 1 39.00
42060aa040 fuel pump gasket 1 17.00
42072ga061 fuel filter 1 L SERIES 10.00
42072ka020 fuel filter 1 FIORI 15.00
44165ag000 gasket 1 10.00
45122ga121 fan blade 1 80.00
45122ga160 fan blade 1 82.00
45161ae060 hoseh6 1 28.00
45167fc000 hose 1 34.00
50812aa010 stay hood lock vert 1 48.00
51551fe040 rh inner lower panel 1 135.00
51551fe050 lh inner lower panel 1 160.00
53010sa0609p lh hl panel 1 110.00
53060ag0009p upper frame 1 90.00
53060sa0409p top lock 1 105.00
56410ag140 engine under cover 1 210.00
56410ag141 engine under cover 1 210.00
57150ae020 lh headlight bracket 1 9.00
57260fa000 rh bonnet hinge 1 20.00
57260fa010 lh bonnet hinge 1 20.00
57330aa010 trunk cable 1 75.00
57430fa021 key 1 170.00
57531ag000 trunk striker 1 15.00
57707ag031 lh bar bracket 1 50.00
57707ag080 lower centre bracket 1 34.00
57707fg050 front bar lower bracket 1 35.00
57711fg0109p rr bar reo my10 forester 1 170.00
57719aa001 screw front bar 3 3.00
57730ac040 REAR bar cover 1 93-98 LIBERTY 350.00
57731fe320ga rh fog cover 1 75.00
57744fa230mh lh fog cover 1 215.00
59110fa010 lh splash (GUARD LINER)1 impreza 30.00
62240fe070 sash window 1 60.00
63269 fe 210 stay assy kit 1 10.00
63511ag000 weatherstrip 1 140.00
63521fe030 weatherstrip lh 1 285.00
64619fa501mu seat belt 1 420.00
64662ag100jc seat belt 1 430.00
65021ac080 seal 1 8.00
65023ac000 screen mould upper 1 50.00
65023ac030 screen mould upper 1 50.00
65407ag000 cover 1 9.00
65407ag010 cover sunroof lh 1 9.00
65409ag000 repair rod sunroof rh 1 24.00
65550ae002ml tonneau cover 1 200.00
65552ac000mu stopper 1 12.00
72411fe001 heater hose 1 22.00
73741fe001 belt cover 1 9.00
760102330 door stopper 1 1.50
81890fa050 bracket 1 16.00
83370aa001 stop lamp switch 1 48.00
84001ac051 lh headlight assy 1 240.00
84001fa260 lh headlight assy 1 300.00
84401ac020 lh repeater lamp 1 LIBERTY 27.00
84701ag001 hi mount lamp 1 330.00
84927ac120 rh fog light bracket 1 100.00
84927fa001 rh fog light bracket 1 43.00
84953fc040 rh fog cover 1 64.00
84501fe080 fog light assy 1 impreza 2000-2001 check vin suitability 300.00
86301fe180 tweeter 1 04-07 impreza 70.00
86301fe190 tweeter 1 04-07 impreza 70.00
90810pa010 clip 5 2.00
91017fa010 clip 1 5.00
91057fc220 rh frnt side garnish 1 370.00
91057fc230 lh frnt side garnish 1 370.00
91059fc010 rivit 1 5.00
91121ag010 grille (badge bad) 1 liberty 5/2003-6/2006 340.00
91131ac000 protector whl arch 1 28.00
91141sa010 cover 1 80.00
92114ag011jc console lid 1 160.00
92122fe010oe gear lever cover 1 37.00
93033fe020 badge rear 1 75.00
94061ae030 sill cover 1 18.00
j501sfg300jh (-J515EFG000)cargo tray 1
sa931 rear muds 1
84401AC020 side turn lamp assy (liberty) 22.00
15208KA010 Fiori oil filter
42072GA061 Fuel filter Lseries
42072KA020 Fuel filters x 2 Sherpa
32018AA002 Switch low range indicator dual range
83071AE071 Main power window switch Impreza
731320010 LH Tie rod end Brumby
492105602 Starter solenoid Brumby
57260FA010 LH hinge bonnet Impreza
83191AE001 ignition switch and steering lock assy Impreza
64619FA501MU Seat belt front RH Impreza
64662AG100JC RHF Seat belt Lib/Outback
13.1.11
93080FA570 Impreza LX Decal X1
807611031 hose X1
800410010 flywheel bolt x1
802642010 lock nut X1
802618010 Pinion lock nut X1
11126AA040 sump plug washer X1
11051AA070 D Seal x4
35173SA000 Shift lock solenoid Impreza x1
Posted: Wed Aug 10, 2011 7:25 pm
by guyph_01
Pm sent
