Sun holds a great deal of energy within itself. The planet receives so much energy from sun in the form of its light and heat that it can power the whole world for years to come. The solar energy can be tapped by collecting its heat or by converting its light into electricity. This can be done by installing solar panels or solar power plants. The solar power plant or photovoltaic cells are made up of silicon alloys, which absorb photons emitted from the sun. The photons hit the silicon atoms in the PV cells, transferring their energy and releasing the electrons from their orbit around the nucleus, thereby generating electricity.
The solar power plant, on the other hand, uses mirrors to reflect the heat energy from a large area onto a small space, such as a pipe filled with a fluid. Once the fluid's temperature has been raised to hundreds of degrees, it can be used to boil water and produce steam for a conventional generator.
Solar thermal investments have increased over the years. The number of solar cells manufactured has risen by 50% in 2007, with its total installed capacity reaching 8.7 GW. The efficiency of these cells has also risen from 4% in 1982 to over 20% for the latest technologies.
Rising Solar Investment
Not wishing to take away any importance of your message but you may need permission to advertise on this forum, especialy being a first time poster here. The system you describe sounds like the system developed by CHAPS at the ANU some ten years ago and sold to a solar water business. I was muuch impressed by it and await seeing it on the market
