windows live on linux
chubby37
Post by chubby37 » Fri Jun 06, 2008 6:40 pm
anyone know how to get windows live to work on linux.i have the exe file but it asks me what i want to use to open and run the exe file
stinky
Post by stinky » Fri Jun 06, 2008 7:26 pm
You can't run Windows programs on Linux natively. There's a package called WINE which will run some Windows programs, no idea about live.
Is it just MSN messenger you need access to? If so Pidgin will allow you to access the MSN messenger network.
BaronVonChickenPants
Post by BaronVonChickenPants » Fri Jun 06, 2008 7:35 pm
I find pidgin a bit limited and occaisionally unstable.
emesen has more features with out adding too much bloat but it's not much better in the stability department.
aMSN is a pretty good clone of Live Messenger complete with all the bloat.
What version of linux are you running Bill?
Jordan.
chubby37
Post by chubby37 » Fri Jun 06, 2008 7:35 pm
how?there were a whole lot of stuff there..windows...source and so on...this is what came up http://www.pidgin.im/download/
chubby37
Post by chubby37 » Fri Jun 06, 2008 7:37 pm
pc linux 07
stinky
Post by stinky » Fri Jun 06, 2008 10:02 pm
after some quick reading it seems PC Linux uses a tool called Synaptic for installing software. If you run this Bill you should be able to find an MSN client in there.
Or you can run this from the command line 'apt-get install pidgin'
