On/Off hub?
On/Off hub?
Is it possible to get like a hub thing that can go onto the back of the flywheel that you can turn on and off, like the a/c compressor hub?
Thanks
midnight.
Thanks
midnight.
stinky wrote:Jaffa, all our important people have been dying doing things they love, Steve was killed playing with his beloved animals, Brockie died behind the wheel ... Mate I don't wanna lose you too, so you should probably stop whacking off.
you mean an electric clutch?
- tim_81coupe
- Brumby Boy
For what purpose is it?
RIP 1992 Brumby
RIP 1992 Brumby
Suparoo wrote:you mean an electric clutch?
Probably.
Suba, I cant use a clutch, as the motor will be on the other side of the shed wall.
I need something that will turn on and off and stop a pulley spinning.
There will be a Air Pressure regulator that will turn the clutch on and off to stop the air compressor going.
D'yall understand what Im getting at?
Basically, I want a F**king huge air compressor big enough to supply enough air to a shed without running out much, as I will be using a lot of air tools, and it just totally sucks waiting for the compressor to re fill.
- BaronVonChickenPants
If you really want to use an EA81 for this why not just use an air con compressor like dave is planning for hatchie, it's already got the mounting brackets, the belts, the electric clutch?
You could always use 2 if 1 didn't provide enough air.
Jordan.
Jordan.
Daza: Would a motor putting a normal clutch on be strong enough?
BVCP: I cant use normal car a/c compressor as I already have the compressor unit, and the motor.
Wilbur: I dont have that kind of money to go and get a big compressor. Besides, I already have most of the parts here to do it. Just need the clutch mechanism, and tank.
- vincentvega
buy an electric mate. the tank is gonna cost you a fair bit plus all the other incidentals.. you can get compressors dirt cheap these days.midnight wrote:and tank.
the noise of an EA81 running next your shed would be a nightmare aswell
- vincentvega
vincentvega wrote:well midnight, what do you want to use it for?
Anything. I just dont want to run out of air much. I hate running out of air and waiting for the compressor to refill the tank.
Foward reverse isnt that hard, just need a couple of relays and contactors, the circuit is easy
