Electronic Wizards
Electronic Wizards
Hey guys,
Anyone here got any experience with low power cables over long distances?
I'm looking to run a cable from the back of our AIS on the bridge down to the Control Room. The distance is about 50mtrs but the laid cable length would probably be closer to 70mtrs.
The AIS has a RS422 comms port and I want to run it in to the Windows 7 Enterprised based PC.
My question is, what is the best way to connect these 2 systems?
Paul
Paul
- Bantum
Networks ...
I'm No expert in this area, but my understanding is that you might need a repeater, no idea how far apart it will need to be though.
See more here : http://en.wikipedia.org/wiki/RS-485
Further : A network hub or line driver, may be what your after : http://en.wikipedia.org/wiki/Line_driver
Add : I just looked up this : http://en.wikipedia.org/wiki/RS-422
It states a max distance of approx. : 1500m ...
So I'd check your unit to see what its specs are - do you still have the instructions ?
Cheers, Bantum ...
Cheers, Bantum ...
Most likely sounds like it will need some sort of repeater/booster I believe.
The AIS is the SAAB R4 Class A model and here is a link to its website tech page...
http://www.saabgroup.com/en/Civil-secur ... fications/
Paul
Paul
- Bantum
Teaser ...
There's a link with a Tech Support help page : http://www.saabgroup.com/en/Civil-secur ... s/#Manuals
It might also be worth a try giving them a bell to find out what's required ...
So does yours look like this ?
& what's the boat this is going in look like ? ...
Cheers, Bantum ...
Cheers, Bantum ...
Can you convert the signal to wireless and back again?
- vincentvega
RS422 will easily do 70m with good quality twisted pair cable.
then just add one of these to your PC
http://www.jaycar.com.au/productView.asp?ID=XC4132
Serial comms is a large chunk of what i do for a crust so any questions ask away.
Yeah.. I did send them an email today.. cheersBantum wrote:It might also be worth a try giving them a bell to find out what's required ...
YesBantum wrote:So does yours look like this ?
A 15,000T floating steel structure that drills holes in the sea bedBantum wrote:& what's the boat this is going in look like ? ...![]()
Nah.. too much steel around.. signal would be lostGannon wrote:Can you convert the signal to wireless and back again?
Perfect. Does this require addition power? What is the best quality cable to use and can we buy it explosion proof (EX rating?) and lastly, can we buy it Aus?vincentvega wrote:RS422 will easily do 70m with good quality twisted pair cable.
Bantum wrote: & what's the boat this is going in look like ? ...![]()
LolRSR 555 wrote: A 15,000T floating steel structure that drills holes in the sea bed
Crikey, what are you planning to do with it?!What is the best quality cable to use and can we buy it explosion proof (EX rating?) and lastly, can we buy it Aus?
- Bantum
Big Bang ...
Says here ...NachaLuva wrote: Crikey, what are you planning to do with it ?!
Sounds like a drilling rig for Gas ...RSR 555 wrote:... A 15,000T floating steel structure that drills holes in the sea bed ...
And you need some form of protection from blow back right ?RSR 555 wrote:...What is the best quality cable to use and can we buy it explosion proof (EX rating?) ...
Got any pictures you can show us ? ...
Cheers, Bantum ...
- Battlewagon
- vincentvega
ExactlyBantum wrote:Sounds like a drilling rig for Gas ...
Yeah kinda.. we need to eliminate any chances of spark/ignition sources.Bantum wrote:And you need some form of protection from blow back right ?
Bantum wrote:Got any pictures you can show us ? ...![]()
That's probably a good possibility. I'll look in to that.Battlewagon wrote:Perhaps avoiding any electrical issues and using fibre optic might be safer?
Thanks VV but from what I've found from talking to people on this site, is there is a lot more to them than just enjoying the fantastic experience of owning a Subaru. So whilst I agree it's not the best place to ask about this stuff, it's great to get people talking about stuff they might even do for a living.vincentvega wrote:mate if your install is running through an EX environment you need to get some better advice than asking on a subaru forum
I would highly recommend you talk to the manufacturer of the gear and go from there.
Thanks for your advise and like I said to before, I've sent an email off to the manufacture of this system and hope to hear from them soon.
