Cant post on: 2014 Subinats 7-9 June?
Ask for help from the Admin / Moderators ...
Willy Fisterbottom
Post by Willy Fisterbottom » Mon Apr 14, 2014 8:57 am
Why cant I post on my thread?
Post by Bantum » Mon Apr 14, 2014 11:43 am
Not Subscribed ? as some sections are 'members' only ...
pay your dues ... :)
Willy Fisterbottom
Post by Willy Fisterbottom » Mon Apr 14, 2014 12:22 pm
Bantum wrote:Not Subscribed ? as some sections are 'members' only ...
I subscribed to the thread but still cant post :(
Post by TOONGA » Mon Apr 14, 2014 2:19 pm
I would like to know what elfen magic you used to be able to create a thread there.
As you are not a gold member there are areas of the board you should not be able to post or create threads in.
Willy Fisterbottom
Post by Willy Fisterbottom » Mon Apr 14, 2014 5:41 pm
I think a moderator moved it. If it's gonna be all top secret I'll keep my info to myself. I was going to start a thread with the mods and brackets I did for my EA81and 5 speed conversion to the 77 model gen 1 but thought I'd be banned from that too, thats why I took down the 5 stud conversion pics too.
Post by El_Freddo » Mon Apr 14, 2014 6:15 pm
Willy, you won't be banned - if the thread has been moved from one subforum to another it's an oversight by a moderator that you're not a gold subscriber and can't post in the subforum they've moved your thread to.
To become a gold subscriber you need to pay $1 or $2 to the forum to access all areas so to speak. I can't remember where you find the details of how or who to pay :???:
Hope this helps. I understand how frustrated you must be!
Willy Fisterbottom
Post by Willy Fisterbottom » Mon Apr 14, 2014 6:30 pm
El_Freddo wrote:Willy, you won't be banned - if the thread has been moved from one subforum to another it's an oversight by a moderator that you're not a gold subscriber and can't post in the subforum they've moved your thread to.
Cheers for that Bennie. :D
So next question is where do I pay?
sublime
Post by sublime » Mon Apr 14, 2014 6:39 pm
Willy Fisterbottom wrote:If it's gonna be all top secret I'll keep my info to myself.
Don't do that Willy, there is not enough Gen I action here as it is!
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
yarney
Post by yarney » Mon Apr 14, 2014 6:40 pm
The post was in the wrong area i moved it to the correct area and put a sticky on it so it will stay at the top
Keeping posts and threads in order makes for a better forum
I didn't realise you're not a gold subscriber
If you subscribe you can access all areas
yarney
Post by yarney » Mon Apr 14, 2014 6:45 pm
Subscription area showthread.php?t=12411
Willy Fisterbottom
Post by Willy Fisterbottom » Mon Apr 14, 2014 7:02 pm
Thanks Yarney. I understand now why it was done, just a shame That some non subscribed members can't now add to the thread, would be good to get as many members as posible at this event.
I will subscribe.
Sublime I agree not enough Gen 1 action, we'll have to meet up. I'm currently organising importing a fair bit of Gen 1 bits from NZ, let me know if you're after any particular parts.
sublime
Post by sublime » Tue Apr 15, 2014 12:12 am
Interesting! Cromwell Auto Recyclers?
What I desperately need at the moment is a Gen I stage II ('77 to '81) bonnet!
Old Boxer Tricks
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
Willy Fisterbottom
Post by Willy Fisterbottom » Tue Apr 15, 2014 12:23 pm
sublime wrote:Interesting! Cromwell Auto Recyclers?
Yes Cromwell, looking at a pallet box at the moment so a bonnet probably won't fit, I'll probably fly over later this year just to have a scrounge throught the yard, maybe I'll get a container and bring back a car or two LOL.
What bonnet are you after?
The one on the left is my 1976 1600 GL Coupe and on the right is my 1977 1600 DL 2 door sedan (now with EA81 and 5 speed).
I have a 1974 1400 DL 4 door and it has the same bonnet as the 1977 model.
Or are you after the same as a Gen 1 Brumby?
Post by steptoe » Wed Apr 16, 2014 7:54 am
it will be the Brumby..... just how many different bonnets for the ugly series?And what other bits are needed to match the differences ?
Willy Fisterbottom
Post by Willy Fisterbottom » Wed Apr 16, 2014 8:38 am
steptoe wrote:it will be the Brumby..... just how many different bonnets for the ugly series?And what other bits are needed to match the differences ?
The grills are different on the 2 types I have, I reckon the guards may also be different on the Brumby shape to accomodate the blinkers on the outside of the headlights. I like my DL bonnets best as the shape looks really good from behind the wheel :)
sublime
Post by sublime » Wed Apr 16, 2014 12:29 pm
OK, Gen I history lesson!
There are two stages of the Generation I Leone:
Stage 1 - 1973 (in Oz) to early 1977
Stage 2 - 1977 to 1979 (1981 for the Brumby)
While stage 1 and 2 look superficially the same the only bits that are the same are the front and rear windscreens, roof skins and some panels such as the floors and sills. Nothing else is common and will not fit. You cannot mix and match between the two different stages, except of course, for most of the mechanical systems (Not suspension prior tor 1975 as this is completely different). For an example, you cannot swap guards, bonnets or doors (the doors will fit in the 'hole' but they are completely different).
There are 3 different bonnets for the Uglies, stage 1 had two versions, one for the dual headlight models and another for the quad headlight hardtops. The stage 2 only had the one version.
Steptoe is correct I am seeking a stage 2 bonnet for the Brumby. I do know where one is, just problematic getting it back to Albury...
The stage 1 models had difference grilles for the DL sedans (in two and four door) and the GL coupes. Also note the front guards a specific as they have different mounting tabs depending on which grille is used (I learnt that the hard way!).
Old Boxer Tricks
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
Willy Fisterbottom
Post by Willy Fisterbottom » Wed Apr 16, 2014 12:58 pm
Thanks for the history lesson.
sublime wrote: stage 1 had two versions, one for the dual headlight models and another for the quad headlight hardtops.
My GL Coupe has the Hardtop bonnet but it may have been changed at one stage......
I have an original parts book for series 1 Gen 1's I'll check it out when I get home.
Willy Fisterbottom
Post by Willy Fisterbottom » Thu Apr 17, 2014 7:19 am
Looks like this thread has gone off in a different direction LOL.
My parts book covers from 1972 to 1974 1400's
Between 72 and 75 five different bonnets were made.
GFT Hardtops (quad light) had the same every year.
Coupes, 2 doors, 4 doors and Station wagons have a different part number for every year.
Return to “Contact a Moderator”
