Have been trying to link 'Titles' to 'Headings' in pages of Subaru Engine List. I did a bit of searching and found this :
Overview :
HTML anchors are links that allow you to jump to a specific place within a document. This is very handy for long documents that have headings or other sections of interest to the reader. Typically, the top of the document contains a set of links to each section, and you need only to click one of those links to jump to the desired location on the page.
Anchors would be just as useful in forums for those who want to make long posts, perhaps for tutorials, forum guidelines or similar types of posts. Since most, if not all vBulletin license holders do not allow HTML in their forums, here is way to create anchors using bbcode instead of HTML.
I have also been experimenting here & have found 'Title Linking' is not currently enabled or is broken ...
In order for it to work, you may need to add / fix this to your 'allowable' bb Code list ...
I think this is what's needed :
Link with further details : http://www.vbulletin.org/forum/showthread.php?t=221348Title: Anchor link
Tag: jumpto
Replacement: <a href="#{option}">{param}</a>
Example: [jumpto=aname]This takes you to a new location within a post[/jumpto]
Description: The [jumpto] tag allows you to jump to another location within a post, usually used for long posts with headings and/or sections of interest. This tag <b>must</b> be used in conjunction with the [aname] tag. One is not functional without the other.
Title: Named anchor link
Tag: aname
Replacement: <a name="{option}">{param}</a>
Example: [aname=aname]This is where you jump to[/aname]
Description: The [aname] tag is used in conjunction with the <a href="#jumpto">[jumpto]</a> tag.
Can this be Done / Fixed to 'Link' Titles ... ?
Cheers, Bantum.
etc ...
