Monsterwagon
- BaronVonChickenPants
The L series outers don't work with the MY hubs, the shaft's don't bed in properly leaving a few mm of play, can make things pretty hairy while driving, and thats was just with one, I imagine that if both front wheels could go where they want it would be brown trousers time. 8O
I have been told that you can put the MY outers on the L series shafts though.
Jordan.
Jordan.
the ej22 with the 3.9 L series 5 speed is awesome
has the power to spin all 4 in 1st high from abuot 2000 rpm
crawl is a little too high for serious 4wding, wont quite hold you going down a steep rocky hill, but going up is a breeze
and i just went in to the tyre shopand told them what they were for and they said navara offset would be the go (after tons of questions about how i was planning on fitting 30's on the soob)
BRUMBERTY would be able to give you more info on the offsets and he just went through it all
navara offset for the fronts on mine,
(which is 50mm wider than the rear due to steering mods)
IFS landcruiser offset for the rear corrected this.
He who dies with the most wheel studs, wins!
1989 Subaru WonderBrumby II
Finally a pic with the ausubaru logo on it
not that u can see it well... but its there
VVV full size version VVV
http://soob.johnnysmultimedia.com/image ... er5big.jpg
