Nannadan the time traveller
- TOONGA
Last weekend I went crazy and pulled the old engine and auto transmission. I'm pretty sure the transmission weighs as much as the motor., it took almost 12 hours to do the whole swap. Mind you at least 2 of those hours were getting the carby to a point where it ran on the motor.
Why? Because I used and L series manifold and carby. What a joy they are to set up without the 1990's emissions rubbish ... not. I set it up like the carby that was on Nannadan, only to have the biggest flat spot followed by a back fire of epic proportions on acceleration or cruising or anything.
What I didn't realise until yesterday after an hour of internet research, is that the main bowl vent and the secondary bowl vent both need restrictor pills, on the lines that come out of them. Now that I have that done the extra power is as good as a weber swap, yet not this is not an over fueled conversion like a weber swap normally is
I have pictures but because stupidbucket wants everyone to go pro they are on Imgur. Sadly not as many pictures as I would like but thems the breaks. I'm not resizing them to put them on the board so you will need to follow the link to view them https://imgur.com/a/PoWur
I'd guess the transmission weighs more than a long block. Those steel gears weigh a ton on Subaru boxes.
Lazy! The trick is to resize each image before you upload to the host site. Works a treat for meTOONGA wrote:I'm not resizing them to put them on the board so you will need to follow the link to view them https://imgur.com/a/PoWur
Fair effort on the swap. What did you do with the different thermostat housing position and hose work to the radiator? Only asking in the event that you have factory PS fitted.
- TOONGA
Suppose so but if you click on them you get heaps of detail.El_Freddo wrote:Lazy! The trick is to resize each image before you upload to the host site. Works a treat for me
No power steering, so I just used a hose that is very similar to the L top hose, as I didn't have one.
That sticker on the door is in amazing condition for its age. I was looking at a door trim just today that had same sticker, or remnants of, and even now reading yours, is as clear as south Australian mud ? as to what one is meant to be doing to observe their instruction.
Engine and trans swap - another auto or fwd5 ?
Reply some time in next 18 months is OK
- TOONGA
LOL Nubaru sorry I missed this. I put in a worked EA81 engine a 5 speed from a wrecked hard top and an EA82 manifold and NOS carby and air cleaner.
some pictures https://imgur.com/a/PoWur
