I have started putting posts up arond the place and thought that i should probably log up my progress.
The Car;
1992 Aniversary Brumby
The donor;
1996? impreza WRX Half cut from Ichiban motors in Moorebank Sydney
So i am definetly no where near as good as the majority of people on this forum and this is my first serious conversion despite being a member of the BYB forover 10 years. I will try and cover all aspects of the conversion to make it easier for others. However like everyone says, there is more than one way to skin cat, and thus do a conversion on a brumby, so my way definetly wont be the only way. So here we go;
Started off by stripping everything out of the engine bay. I took particular care to label all the wiring loom connections with a bit of masking tape and a label and ended up with a long loom hanging over the car. After i got rid of everything from the front of the car (engine, gearbox, lights, grille,etc) i spent hours scrubbing the enginebay to get rid of over 15 years of muck. Here is the result;
Chassis rail modifications (doesnt need to be cut this much but does make it easy to fit, only need to cut where the cam covers woud touch the rail); the photo is obviously after cutting and rewelding. I used a mig welder and the panel out of a bonnet (which is the same thickness as the rail) and then used body filler to round out the corners and then surface primer and then 4 final coats to make it look factory.
