Update on my Brumby
Post by TOONGA » Thu Nov 19, 2015 8:49 pm
Some sadness as a lot of effort has been put into this brumby build wise. But I think it would be better if my son could drive a car that's in on piece when it come time for him to drive :)
Post by TOONGA » Thu Dec 10, 2015 3:28 pm
Some time ago I crushed my unequal aftermarket headers while off road in the national forest behind Brunswick. I've not bothered to try and work out what exactly they were rubbing on, but they were causing gearbox and engine noise to be transmitted into the ute. Today I put a stock header on the engine.
uneven on the left and stock on the right. For the record I stole that photo from a forester board as I couldn't be bothered taking photos of mine. The stock headers I got looked just like those ones on the right which are minus the heat shields. My aftermarket ones looked liked the ones on the left in 2010 when they went on, not so much now.
not only is the gearbox and engine noise gone but I do believe I have picked up some engine power. Or I can drive it without being worried about the mechanical racket. Sadly though my boxer rumble is gone but the vortex makes up for that. :)
Anyone in WA want some bent aftermarket headers? :)
Proton mouse
Post by Proton mouse » Thu Dec 10, 2015 4:13 pm
Interesting (and good) that you have picked up power!!!
Do the aftermarket ones have smaller diameter piping or some restrictive bending?
JB
Post by TOONGA » Thu Dec 10, 2015 4:52 pm
The pipe diameter on the uneven headers from the head collectors to the "Y" joins is smaller, then there are the uneven length pipes which are the same diameter as all the pipe on the the standard headers. If that makes any sense?
I do think it is more about the noise being gone. Having said that it could have to do with the fact that the factory headers are designed to make the engine run at its best.
Post by El_Freddo » Sat Dec 12, 2015 5:36 pm
In terms of unequal length extractors, more noise or beat = less power. Hence why Subaru these days run equal length headers...
I'd love more subi rumble though!
Post by steptoe » Sun Dec 13, 2015 10:55 am
was thinking was reading an old post, but, it is December now ain't it ? :oops:
Post by TOONGA » Sun Dec 13, 2015 12:51 pm
El_Freddo wrote:In terms of unequal length extractors, more noise or beat = less power. Hence why Subaru these days run equal length headers...
how about a set of these then Bennie
I don't remember what board they came from but I did find them when I was looking for stock header pictures.
steptoe wrote:was thinking was reading an old post, but, it is December now ain't it ? :oops:
Yes it is December and occasionally I post stuff in my car threads just to amuse or annoy :)
Phizinza
Post by Phizinza » Sat Mar 05, 2016 8:10 am
So what's the plan for the next project......?
Post by TOONGA » Sat Mar 05, 2016 9:04 am
Phizinza wrote:So what's the plan for the next project......?
don't know yet... First thing I have to do is get a new job.
But this is the canvas PJ MK2
Post by TOONGA » Sun Mar 06, 2016 11:26 pm
A side view of PJ MK2
Post by El_Freddo » Mon Mar 07, 2016 11:31 pm
Nice!
Keeping the EA81 goodness or going the dizzy EJ'd route again?
Post by TOONGA » Tue Mar 08, 2016 9:06 am
I don't know Bennie when I got this one it seemed the motor wasn't happy and I was worried that it had a blown head gasket.
Over the last couple of months I've started it at least once a week to stop the battery from dying.
It has a high idle on the auto choke so I've just been leaving it to run on that until it gets warm and I think it likes it.
I can't really see the spark plugs due to the power steering and aircon, but once I find them I'm going to change them out for a set of AC delco double platinums 41804.
That way I wont have to go near them for around 100000 kms at least.
This week I'm going to tackle the broken gearbox (I'm hoping I will be able to do it) in the driveway where it is sitting now.
Post by TOONGA » Tue Mar 08, 2016 4:04 pm
Gee I say some stupid things like...
Before I took the box I drained it to make sure it was stuffed. I let the oil go and got rather worried. Apart from the normal filings on the magnetic drain plug there were no tell tale bits nice clean gear oil????. Right near the end when the flow turns into a dribble, the dribble split into two and that's when I saw sitting on the drain hole...
crown gear or pinion gear? I guess that's why it was so noisy
I then went ahead and ... well I got the box out
old box in the back replacement on the ground :)
I did notice a new clutch cable, clutch kit, thrust bearing and even the throw out arm looks new.
Now that it is 33 degrees I've stopped for the day.
Tomorrow I will try to get the replacement in :rolleyes:
Post by El_Freddo » Tue Mar 08, 2016 9:28 pm
So what is that in the pic that came out last - a gear tooth or part of a bearing cage? I can't really tell.
What nasty stuff was the box doing in this condition?
Good work on the DIY driveway gearbox drop! You should organise a Subaru convention at yours, many hands make light work (well, the ones that actually get their hands dirty, but good company is always appreciated!).
Post by TOONGA » Tue Mar 08, 2016 10:33 pm
It is either the crown or pinion gear.
The car was like that when I bought it.
Bennie get some glasses :)
Post by steptoe » Wed Mar 09, 2016 6:59 am
I is wondering how it would have run if you filled up with oil and took it for a test drive now you have one piece of stuff out of the way of the gears. We'll never know now :(
Top marks on removing the gearbox with engine in place. Were you directly underneath, taking the weight of the lump, and is this how it goes back in? Or do you have some WA drop/lift secret tool ? I would still remove engine to get at gearbox :oops:
Post by TOONGA » Wed Mar 09, 2016 8:31 am
I don't need to know if that bit was missing from either the crown wheel or the pinion shaft then the box is toast.
If you look at the second picture in the post you will see the secret magical device I used to get the box out. As well I just pushed it out from the engine bay and let it hit the ground. the old box is going to the tip. So I wasn't too worried about how it came out, as long as I wasn't under it when it did come out. :)
Getting it back in will be more of a challenge, as I don't have a balance plate to put on the jack (secret magical device) I will say the day Bennies box went back in up in Perth it did give me a few ideas on how to get the box in.
The video below is the noise the box was making when being driven. Ignore the wires hanging out of the dash I must put a stereo in yet.
https://www.youtube.com/watch?v=SqtLwoh ... e=youtu.be
Post by TOONGA » Wed Mar 09, 2016 2:20 pm
Everything bar the inner CV's is back in, I'm currently running in rear wheel drive. That will change tomorrow morning when I have finished inspecting and re-installing the Front CV shafts.
For the record I started at 9am and finished at 11:55 am, I'm hoping I don't have to do that again in a hurry.
Post by El_Freddo » Wed Mar 09, 2016 5:01 pm
Glasses? Something in the pic for reference of size would be better :p
Or you can sponsor me for a phone with a larger screen :p
On the subject of how the box would go with that missing tooth, it could tick with each revolution and would most likely end up dying with some horrible and loud noises... Worst case it could lock the front end or put the car into a spin as the front diff could allow one wheel to spin forwards and the other to turn backwards, or at least rotate at a slower speed than the other wheel inducing the spin...
Fair effort on those times there mate!
Post by TOONGA » Thu Mar 10, 2016 9:55 am
El_Freddo wrote:Glasses? Something in the pic for reference of size would be better :p
I would need sponsoring first to sponsor you :)
El_Freddo wrote: Fair effort on those times there mate!
Feeling it today Bennie :) and I still have to sort the front shafts out.
