I own a vortex :)
Subydoug
Post by Subydoug » Sun Sep 14, 2014 10:31 am
No worries mate, she sounded sweeeeeeeeet! To anyone thinking of doing this I would suggest a second pair of std headers. We ended up cutting the flange off of one and spinning it 180 degrees. I should make one for the wagon, but I think Il use new stainless, just so I can tig it.
Doug
Post by TOONGA » Sun Sep 14, 2014 6:26 pm
I would suggest either the second set of headers or as Doug said when we were making the headers, cut the bends off the factory headers and mate the two shorter tubes to the new pipes.
Post by NachaLuva » Mon Sep 15, 2014 12:41 pm
Can you post a side on pic of the headers so we can see how the short side blends in?
Really impressed with this. It would give an awesome boxer rumble :twisted:
Have you noticed any change in engine performance?
Post by TOONGA » Mon Sep 15, 2014 10:01 pm
Ok short side isn't pretty but is functional
As for change in performance it sounds faster :)
I seem to be driving a bit more like a yobbo as it sounds great.
Still no usable video sorry.
I spent this afternoon chasing a fuel pump relay gremlin, only to have the problem solved by changing relays around and tugging on a couple of wires.
Very professional :rolleyes:
Post by NachaLuva » Tue Sep 16, 2014 12:43 pm
May not be pretty but looks strong & more importantly no leaks! :D
Post by TOONGA » Tue Sep 16, 2014 7:17 pm
Yep Doug did a great job.
I'm thinking the engine may actually be more responsive at low revs now. I have less problems with my heavy duty clutch wanting to argue with the flywheel, when I have to ride the clitch on a hilly intersection.
Post by TOONGA » Sun Oct 19, 2014 9:13 am
I'm having a problem with my EJ22 it has an intermittent start fault cold or hot
the engine will crank and nothing, then when I crank it again it backfires, then when I crank it runs like it has flooded. (which it has)
I've changed ...
The coolant temp sender (new)
the knock sensor (new)
the crank angle sensor (working second hand unit)
the cam angle sensor (working second hand unit)
the igniter (working second hand unit)
the coil pack (working second hand unit)
the afm (working second hand unit)
the O2 sensor (working second hand unit)
the ECU (working second hand unit) both have been reset
the ignition relay (working second hand unit) and the franken relay
And my car still does it :(
I'm going to check to see if the timing belt is lined up tomorrow if I have a rain free period. (it is the only thing I can think of)
Venom
Post by Venom » Sun Oct 19, 2014 9:37 am
Yeah I was going to say maybe the cam sprocket has slipped a few teeth on the belt.
Post by TOONGA » Sun Oct 19, 2014 11:56 am
So I just had a total WTF moment... I pulled the plug lead on number 1 and put a screwdriver in to check for spark ... nothing on crank, so I moved the screwdriver and I tried again I got spark and the car ran on the other 3 cylinders.
I tried to put the lead back on but the engine stalled before I could get it back to the plug. Once again when cranking nothing, the car won't run and the bolts holding the cam covers on are spinning due to the plastic breaking around the lugs. I have given up due to rain and total frustration.
It is definitely not fuel as the plugs are drowned somewhere in the electrical/spark department there is a problem that I cannot diagnose.
Subydoug
Post by Subydoug » Sun Oct 19, 2014 3:44 pm
Check your ground strap. Also check the resistance thru the lead while manipulating it. IF it changes at all, throw it in the bin.
Doug
Post by TOONGA » Sun Oct 19, 2014 5:17 pm
I got one of the cam covers off and the timing belt it still on, whether it is in place or not remains to be seen. Maybe tomorrow after work if it isn't raining I can get the other side off and see where the marks are. Looking at the belt though I may need to fork out for a for a kit soon :(
/ EDIT
Rain stopped long enough for me to get the other cover off... when the left (passenger) cam wheel is lined up the right cam wheel (drivers) is 2 teeth out and I got the same result when I tried to line them up the other way :(
Post by TOONGA » Sun Nov 02, 2014 12:52 pm
So still no progress on starting this engine :(
I have the timing covers off and finally got the crank pulley off, and it seems the timing is all in line WTF. Probably would be a good idea to put a belt kit through this, as it appears to be the original subaru timing belt. Even though the engine has recon heads.
In the meantime I'm back at sensors and anything else thats electrical. That is when the battery is fully charged :( it hasn't liked sitting for two weeks.
Post by El_Freddo » Tue Nov 11, 2014 9:45 pm
Might be time to look at the condition of the injectors ;)
Post by TOONGA » Sun Dec 07, 2014 9:37 pm
Ok so it is a month later and I had a visit from RSR555 today and much progress was made. A big thanks as well for fitting the belt for me.
I decided to buy a timing kit from EBAY USA as one from subaru would've cost more than what I paid for the car, just about :)
Which we installed today no pictures of that as we were both putting bits into the car.
As well my new radiator went in, I have pictures of that as it is a mazdaradiator that was modified a little that works a treat.
the radiator
with new inlet and outlet pipes
test fit Sooooooo much more rooooooom oh wait the front of the motor is off
in and running like a bought one :)
the ninja approach to holding a radiator in place
It works a treat :)
Thanks again Paul
Venom
Post by Venom » Mon Dec 08, 2014 6:10 am
So that rad squeezes in under that top panel where the old one sat behind it? That wouldve give. you about an extra inch clearance, very cool ;) What is the rad from and how thick is it? Never mind followed your link... Thats what ive been wanting to do with my car for a while to free up some space, that one might fit too.
Post by TOONGA » Mon Dec 08, 2014 7:19 am
What I did to get it to fit was to cut the original mazda mount points off, then I cut the bottom structural / support panel of the radiator down by 5mm on both "rails" and the back one on the top rail. I don't have photos of that sorry. I thought I took some but I can't find them.
And it is definitely squeezed in there, it goes in and comes out but it is a fun little fit.
Post by TOONGA » Mon Dec 08, 2014 8:13 pm
So I got home from work today and I'm under the bonnet marvelling at my radiator install and I see water leaking out of "SOMEWHERE?!!??!"
first and most obvious thing to do check all the hose clamps and my solder joints ... clamps are a little loose but not leaking niether are my solder joints.
Under closer scruitiny I notice the water is coming from the bottom of the drivers side end tank, nowhere near my soldering. seems who ever soldered the radiator up either missed a spot or it didn't solder properly.
So now I have a choice to make a radiator stop leak either silver seal or the copper brand, or pull the radiator out and find and fix the leak. :(
grumble grumble grumble
Subydoug
Post by Subydoug » Tue Dec 09, 2014 7:52 pm
That sucks mate, I hope its an easy repair. An egg down the throat does the job to :D.
How are those headers holding up? no leaks or cracks?
Doug
Post by TOONGA » Tue Dec 09, 2014 9:03 pm
Headers are doing great Doug, Paul loved the sound they made when we went for a drive. :)
Black or white ground pepper is another small leak fix. I found out years ago that a certain well know brand of stop leak was chook pellets egg white and pepper.
I bought the copper seal from the local parts store.
I should really pull the radiator out and re solder the leak.
sighs...
Post by TOONGA » Wed Dec 10, 2014 7:27 pm
So this has happened 2 mornings in a row around 8-10 degrees celsius both mornings.
turn the ignition nothing... it won't start, turn it off and back on for the fun to begin.
Damn thing starts ok in the afternoon on the second turn of the ignition.
any ideas
https://www.youtube.com/watch?v=ewSC0qQ ... e=youtu.be
