B00stings 92 Brumby
B00sting
Post by B00sting » Sun Jan 22, 2012 6:37 pm
Well, bought a landcruiser snorkel for 10 dollars.
Figured out parts for a rear diff breather and ordered them as well.
-97 Landcruiser :D
Post by El_Freddo » Sat Jan 28, 2012 8:58 am
So you found the breather in the end?
And the cruiser snorkel, I'll be keen to see how you get this one to fit!
B00sting
Post by B00sting » Sat Jan 28, 2012 2:56 pm
El_Freddo wrote:So you found the breather in the end?
Not exactly :) (Think it was actually non-existant!:eek: )
So will I!
-97 Landcruiser :D
Post by El_Freddo » Sun Jan 29, 2012 8:28 pm
B00sting wrote:Not exactly :) (Think it was actually non-existant!:eek: )
You need to remove the moustache bar, then clean out all the mud/crap that's behind that. It should, from memory, be on the driver's side of the diff's rear plate. It'll pop out with a little force ;)
Post by steptoe » Mon Jan 30, 2012 8:41 am
here is a pic !
Uploaded with ImageShack.us
B00sting
Post by B00sting » Mon Jan 30, 2012 5:10 pm
Fantastic!
Much appreciated Steptoe and El_Freddo! :)
-On the weekend I got some new road tyres, the mud tyres are just too good to punish on the tarmac, so dedicated offroad tyre set exists now!
-Next step is to get the disc brakes on the brumby (partially taken off, waiting on socket for impact wrench to arrive for vortex hubs!), at the same time I will get new suspension fitted and CVs.
-97 Landcruiser :D
B00sting
Post by B00sting » Tue Jan 31, 2012 4:35 pm
Looking at EJ25s.
Only seem to be finding the DOHC or turbo versions though.
Anyone know how much chassis rail modification is required for a DOHC model (99ish)?
Aside from that is it the same as the SOHC?
EDIT: Curious to know how much lift is required before no chassis rail modding is needed???
DOUBLE EDIT: Found two spare front guards to chop! :) will also fit the flares I got from guy.
-97 Landcruiser :D
B00sting
Post by B00sting » Sun Feb 19, 2012 6:32 pm
So today I...
-Ran the hose for rear diff breather to front of car, dummy installed air manifold for diff breather setup also. Ordered the two filters needed which will run up snorkel.
-Fitted the 2nd hand ROLA roof racks I got off eBay for a bargain price.
-Sorted out the courier for the two front guards (that are going to get chopped and snorkel fitted/flares).
Picture of roof racks (excuse the fisheye lens)
EDIT: Bought a UHF which should arrive next week.
Deliberating over suspension setup/lift amounts etc...
Trying to part out the vortex on the odd chance i'm actually home!
EDIT2: (to save on new posts! lol)
-Ordered crossbred lift kit and diff bash plate!
-bought a hilux snorkel due to the cruiser one pissing me off (and it only cost 10 dollars). the hilux onemounts on the passenger side which is preferable for me, and i can use bits from the cruiser snorkel to mix n match if needed. also bought a gutter mount for uhf aerial which will in fact be used to mount snorkel to save drilling holes in pillars!
-97 Landcruiser :D
B00sting
Goodies arrive!
Post by B00sting » Tue Mar 13, 2012 4:26 pm
Bits and pieces arrived!
Hopefully getting suspension setup front/rear within 2 weeks also!
Crossbred body lift kit & rear diff protector:
ARB CKMA12 compressor & tyre inflation kit:
GME tx3440 UHF, bullbar mount for aerial, gutter mount for aerial:
-97 Landcruiser :D
Post by RSR 555 » Wed Mar 14, 2012 9:47 am
I bet it feels like xmas :cool:
Need before and after pics of the lift kit installation too :p
B00sting
Post by B00sting » Thu Mar 15, 2012 9:08 pm
Sure does mate.
Got the UHF in after work today, in but not tidy so will sort that out tomorrow.
New snorkel is a safari snorkel to suit a hilux 83-88 (P/N:SS65HF)
Used but good condition, looks like I can make it work a lot easier than the cruiser snorkel (but I can use this for parts, maybe airbox also).
Am not cutting guards until lift kits are in...
-97 Landcruiser :D
B00sting
Post by B00sting » Tue Mar 20, 2012 5:37 pm
If all goes well I'll have an 02 outback, dual range manual, EJ25 donor car within a month! 8)
-97 Landcruiser :D
ScubyRoo
Post by ScubyRoo » Tue Mar 20, 2012 6:42 pm
This thread needs pictures!
PICTURES!
B00sting
Post by B00sting » Tue Mar 20, 2012 7:05 pm
ScubyRoo wrote:This thread needs pictures!
PICTURES!
my camera is stuffed and only have a gopro with a fisheye lens! :D
will try.
probably going to sell my gas gas 300 also barely ride it anymore and will use cash to fund conversion!
EDIT: deposit put down!
Specs:
-02 outback running no panels though
-ej 25 sohc
-dual range manual
-4.44 gears! (hell yes!)
-low as kays
EXCITED!
EDIT 26/03/12- Outback half paid off!!
-97 Landcruiser :D
B00sting
Post by B00sting » Wed Apr 04, 2012 6:37 pm
So I need the vortex gone, its nearly complete manual rare as hell gearbox 5 speed. $400 whole car will get it rolling (see add in FS section). located in melbourne.
Outback paid off in full!
now to pickup the ej25 goodness!!
UPDATE:
-vortex gearbox removed, roof cut off, all other bits people wanted removed!
-vortex ready to scrap!
--Lookout for a vortex 4WD 5 speed on ebay with all vacuum linkages, shifter, turbo crossmember and diff locker switch (standard) SOON!!!
01/05/12:
-vortex gone!
-outback moved in!
-starting conversion mid may weekends only at first due to work.
-97 Landcruiser :D
B00sting
Post by B00sting » Thu May 10, 2012 6:45 pm
Things are in motion!
Car is off the road from the 17th May to whenever it takes to finish!
Waiting to go on: strut lift, rear lift conversion also, 2" crossbred body lift, ej 25 sohc, d/r 02 outback gearbox, custom driveshafts, rear disc brake conversion, and the list goes on.....!
trying for everything to be engineered or able to be engineered later on.
-97 Landcruiser :D
thunder039
Post by thunder039 » Thu May 10, 2012 6:53 pm
B00sting wrote:Things are in motion!
sounds good!
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
AshR
Post by AshR » Sun May 13, 2012 10:58 pm
This thread needs photos, I'd even settle with pics from an old nokia atm this sounds like it's going to be epic.
keep us posted how you go :)
Post by RSR 555 » Mon May 14, 2012 9:13 am
B00sting
Post by B00sting » Thu May 17, 2012 7:07 pm
ok ok i'll get some damn pictures! :p
vortex box now on ebay!
Subaru Vortex 1989 AWD gearbox! 5sp manual, diff lock model. now on ebay!
-97 Landcruiser :D
