I own a vortex :)
What are you trying to look for?TOONGA wrote:Ok then not what I was looking for
I will have to play with the plugs for the engine harness.
Which plugs? EJ or EA?
Doesn't matter if you have A/C or not. All XT's have EFI and this plug for the dizzysteptoe wrote:That white plug, don't recall it. Mine is no AC - may be why I not know the plug )s)
IMO, there is too much involved in trying to use the A/C wiring, as the original system uses pressure switches in the A/C lines before the system will switch on the compressor clutch (which I guess you were wanting to use to activate the spot light relay). I would suggest running a twin core wire from under the bonnet in to the cabin switch and use the wiring diagram on this forum to wire it up the spotties.
- TOONGA
Yep I want to use the switch to trigger the relay and yes I was going to plug in my recently aquired MPFI engine harness (freebie) and see if I could find the wires with the FSM and a bit of trickery.RSR 555 wrote:IMO, there is too much involved in trying to use the A/C wiring, as the original system uses pressure switches in the A/C lines before the system will switch on the compressor clutch (which I guess you were wanting to use to activate the spot light relay). I would suggest running a twin core wire from under the bonnet in to the cabin switch and use the wiring diagram on this forum to wire it up the spotties.
It may well be easier just to run a 2 core wire to the switch and go from there to the relay and light active.
- TOONGA
MMMMM ... twin core wire funnily enough I was looking for twin core wire under the bonnet of a 93 sedan when I found this...
It is a nice little converter from the 3 or 4 plug to the 2 plug alternator.
I'm just curious as to why the resistor was put in between the 2 wires, and according to the resistor calculator it is 69 ohms
MMMMM.... 69 ohms
MMMMM.... 69 ohms
Not sure on the resistor but not sure how they make a 3 wire into 2 wire? Wonder if this is where the resistor joins onto??
That cleary white plug looks the same as another plug on the Subaru.. just can't think which one
No sh!t sherlock... they should have got you to star in that new tv seriesTOONGA wrote:The white plug is where the 3 or 4 plug alternator plugs in, and of course the other end goes straight to the 2 plug alternator.
And that should be 3 or 4 PIN plug
I meant it looks the same (size and shape) as on another Subaru modelTOONGA wrote:the white plug kinda looks like the main engine harness plug for a brumby but is bigger
- TOONGA
Which one the English Sherlock which started 2010 or Elementary which Started last yearRSR 555 wrote:No sh!t sherlock... they should have got you to star in that new tv series![]()
Yeah the brumby plug doofus, and the last time I didn't explain something to you in primary terms you had a sook for a weekRSR 555 wrote: I meant it looks the same (size and shape) as on another Subaru model
Quite possible it is the same as the plug from a later model.
Your choiceTOONGA wrote:Which one the English Sherlock which started 2010 or Elementary which Started last year
Primary?? how about using english terms like the rest of usTOONGA wrote:Yeah the brumby plug doofus, and the last time I didn't explain something to you in primary terms you had a sook for a week
- TOONGA
Apparently one of the 3 wires goes to the ECU and this tells the alternator to start charging http://bbs.legacycentral.org/viewtopic.php?t=18135. so perhaps the resistor fools the ECU. or just gets really hot and glows for that extra ricer effect.
I was under the impression that the 4th wire went to the ECU and the 3rd wire went to the dash? Need to see wiring diagram to see for sure.Subydoug wrote:May be a pull up resistor. Maybe the 3/4 pin sends out a signal to the ecu to indicate charge?? donno without having a bo peep. Looks like that resistors been getting hot though.
Who you calling old?Subydoug wrote:You two are like a married old couple.
