My 1985 Sherpa
My 1985 Sherpa
Guys just wanted to show you what you can do to a Sherpa even when everyone tells you nothing will work, well i found wheels, tyres and all needed to make the car look tough
There wheels are 2007 Honda Jazz wheels, the only mods to fit them was tap the rear coil area flat in the rear gaurd and machine the brake drum hub flange down to 55mm, the front had no issues at all
The tyres were quite hard to find in OZ, but after some research in found Federal made them, there size is quite rare in OZ, there 155/55r14
Then some adjusting of the coils to get the ride height down and done, a sweet sitting Sherpa
Painted the bumpers satin black to break up the yellow a bit, and the tint, mmm
Modified the dash to hold a CD player in the factory spot, i had to drill out all the spot welds on the heater controls and choke mount and mover them all forward 25mm, then refit, CD fits perfect now, made alloy plates to go behind the rear side panels to mount the speakers to, and it sounds great with only rear 6x9's
JET
JET
- IMG_2571.jpg (55.86 KiB) Viewed 6290 times
- IMG_2569.jpg (58.49 KiB) Viewed 6281 times
- IMG_2567.jpg (59.34 KiB) Viewed 6286 times
- IMG_2566.jpg (57.17 KiB) Viewed 6301 times
- IMG_2564.jpg (64.7 KiB) Viewed 6307 times
- Chris_Rogers
- Chris_Rogers
Wanna make a bet Chris, i am making a slide mech to fix that issue, will take some mucking around, but it'll workChris_Rogers wrote:you have no choice on the rear. keylock is integrated into the barrel.
It will be a slide driven by an actuator, the slide will have a hole in it at the unlocked point where the pin from the barrel will go though to open the door, in the lock pos there will be no hole, and the pin will hit the plate!!!
- Chris_Rogers
this I want to see...JET-6 wrote:Wanna make a bet Chris, i am making a slide mech to fix that issue, will take some mucking around, but it'll work
that beat me on both of mine!
Chris_Rogers wrote:this I want to see...
Here is the barrel mods to do it, changed from a sliding plate to the rod, all the was required was a 35mm stainless hose clamp, a 6mm bolt, and the rod that come from the central locking kit, bit of cutting, some drilling and tapping
Not much to look at but you cant see it anyway, its very strong, im very happy with it so far, check the pics
The rod slides inside the hole drilled in the 6mm bolt, its threaded into the hose clamp and the lock, then the hose clamp is done up to shift the thread a few thou and it locks the bolt in the right location, this can also adjust the preload and the shaft, little bit of locktite once ive re-installed it and it will be sweet as
- IMG_2583.jpg (48.63 KiB) Viewed 6181 times
- IMG_2582.jpg (52.25 KiB) Viewed 6181 times
- IMG_2581.jpg (52.95 KiB) Viewed 6193 times
Ok got the rear door installed, well it worked out very well indeed, have a look at the pics, some 3mm alloy plate and some screws and bobs your uncle, tests out perfect, now just to do the front door and im done!
EDIT: Just got one of the doors done, came up sweet and system is working well, just the drivers door to do and its done, then wire the interior light to the drivers door, needs a switch put in
- IMG_2586.jpg (42.06 KiB) Viewed 6180 times
- IMG_2585.jpg (36.71 KiB) Viewed 6182 times
- IMG_2584.jpg (45.64 KiB) Viewed 6186 times
