Hatchie Mayb up for a mid life overhaul
So since the ej22 is dead in hatchie (massive blow by and death rattle). I've been thinking once I finish my current project I'll give the hatch a birthday and bring it into this generation
So my thoughts so far
Possible h6 maybe even supercharged. Space depending
Crossbreed kit
Liberty dual range with lower low range
And liberty or outback interior including air con
At the same time respray and rust removal before it takes over anymore than it already has
Any other ideas or thoughts suggestions
Cheers Tristan
Crossbreed kit
Cheers Tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Yes will have to do some measuring for the h6 luckily I no some1 with a half cut and a outback with one in it hopefully there will b enough room for a rad and air con but only time will tell for that
Cheers Tristan
Cheers Tristan
There is a EG33 (SVX) engine fitted in a Gen2 Brumby so I would say the EZ30 would fit for sure, as it's physically smaller overall. You can come over with your tape measure when I get home.
Well today I brought a 2001 h6 outback. Think it has 166 ks on itI front rh damage. Minor tho but enough to set the air bags off
might fix it and then use it as a driver until I'm ready to strip it down all depends on how difficult the licencing department want to be
Will post up pics 2morrow wen I pick it up
Tristan
Tristan
Before doing any work on the Outback, first check with the DOT to make sure it's not a Stat Right-off
yep its a repairable write off so thats another inspection 160 bucks and then if it passes that then off to licencing center
here are some pics off the web page
[ATTACH]3514[/ATTACH]
[ATTACH]3515[/ATTACH]
[ATTACH]3516[/ATTACH]
[ATTACH]3517[/ATTACH]
[ATTACH]3518[/ATTACH]
tristan
tristan
- 34883326F.jpg (13.05 KiB) Viewed 10183 times
- 34883322F.jpg (15.58 KiB) Viewed 10181 times
- 34883321F.jpg (15.43 KiB) Viewed 10183 times
- 34883325F.jpg (19.68 KiB) Viewed 10183 times
- 34883324F.jpg (17.36 KiB) Viewed 10184 times
Put the engine in Hatchie and sell me the other bits to fix my OB.. win win
slight up date
after seeing the hatch parked in front of the shed not going (and talking with rsr) ive sourced a cheap ej22 but unknown condition
i pulled the engine out tonite and hopefully all going well ill have the new ej22 in tomorrow
and then i will slowly start doing a bit of rust repair while being able to get a subi off road again
tristan
tristan
- Bantum
Go'er ...
Looks repairable, all you would have to do is fix the door & fender + new Air bags ...90brumby wrote:
Not sure how much it's going to cost though - Can you give us an update when your done ...
P.S. - Do you know what happend ? Did Someone run into it ?
goodluck with that part of it, i thought about that for another car called the only people i could get to have them replace the airbags and it was rediculous... what airbags were set off?Bantum wrote:Looks repairable, all you would have to do is fix the door & fender + new Air bags ...![]()
to do list:
to do list:
