offsets, subaru and 6 stud
hi all.
im about to do a 6stud conversion.
Just wondering what offset is standard l-series and what offset are the l-series speedy 14in rims.
Also what offset are the bigger 4wd's and which model is likely to be of a similar offset to l-series.
thanks.
thanks.
- brumbyrunner
- brumbyrunner
Phizinza has done it (6 stud conversion) and i believe he has superlites off a mazda bravo or something similar. Offset is pretty good
i believe this is Phiz's webpage which first gave me idea.
A really good DIY
http://webmaster.beverleypaine.com/6stu ... rsion.html
A really good DIY
- brumbyrunner
Just had a read of that link!
My goodness that's a rough job and the description gave me a good chuckle too. I do hope if you're going to redrill your hubs you use a little more finese. That's kindergarden grade stuff!
But what is wrong with a 4 stud 15 x 6 Performance Superlite?
Settlement Creek Racing
there's nothing wrong with the superlite's i actually like them. Im just worried about how they stand up off-road.brumbyrunner wrote:Just had a read of that link!
And what sort of price do they go for? availability? If they go ok off-road im more than up for some.
Im pretty sure that the superlites are close to $1000 a set.
- INEEDABEER
thats abit toooo much for me to justify on my poor wagon lol.Suparoo wrote:Im pretty sure that the superlites are close to $1000 a set.
and i dont think it would weaken the hubs at all. Radial force is f/a especially with 6 lugs.
- brumbyrunner
- stamp_licker
I've got a set of steelies off a early pajero 15x6 the offset is better than the speedy 14" rims,the paj rims sit in more.I can measure the offset if you like.I'm sure you seen heaps of post over on the usmb about 6 stud conversions.I wouldn't be too worried about strength,legalities are like every other mod on a subaru
Building a hardcore postie:D
Correct.brumbyrunner wrote:I don't think the hub is likely to crack unless you're in a bad accident but I understand the mod is illegal in all states.
It is a hard drill, get them done if you have even moderate skills.
I got them done for me by a bloke with MACHINING skill.
Getting them wrong in the drilling(I have done that too) could be catastrophic.
Apart from that...
I have jumped them,
Spun them,
gently crashed them,
and generally abused them by rallying through nasty rocky roads/tracks with two thumbs up results.
Depending on the budget....give it a go.
I am a happy camper.
1989 Subaru WonderBrumby II
>sorry if I sound new to this, that's because I am, but I was on the understanding that changing rim size or tyre size would affect the speedo reading. Is this not true with Subarus??
It all depends on the total outside diameter. When I went from stock 13" to 14" I dropped from a 165/70/13 to a 185/60/14 (this is from memory, it may have been 165/75/13) and the overall increase in OD equated to a couple of k's @ 100kph. Generally most speedo's are conservative ex-factory also (bloody good thing in speed camera mad Victoria). Obviously, as the rim gets bigger the tyre needs to go lower profile to keep the same OD - I think it's about 50/55 profile in 15" which is definitely not off-road material
Dean.
Dean.
i like your style. LolBRUMBERTY wrote: gently crashed them
Id also recommend getting them professionally machined. I know of a few good places that are not going to charge you an arm and a leg and do a lot of automotive work also.
Hunter S. Thompson
Hunter S. Thompson
