14 inch
Posted: Wed Jan 09, 2008 6:52 am
by 54ROCKER
Hey guys this is my first post here so Gday
i just wanted to find out if i can but 14 inch wheels on my brumby without doing the lift kit ?
or if i have to do the lift kit how much will it be
im from perth area so if use could help that would be great
Posted: Wed Jan 09, 2008 10:24 pm
by Suby Wan Kenobi
You will fit a 14in rim on your Brumby without a lift kit however you will not be able to have huge tyres on them as well but there are still plenty of tyres to choose from in what you will be wanting.
Posted: Wed Jan 09, 2008 10:40 pm
by Suby Roo
14 inch rims will fit fine and from what ive heard, most people run a 185 60/65 tyre.
Posted: Wed Jan 09, 2008 11:02 pm
by Jack
Bling your car with 18" chrome wheels and 35 profile tyres.
Posted: Thu Jan 10, 2008 5:47 am
by 54ROCKER
Kool
so i can put 14 inch wheels and i wont have problems with scraping of the guards ?
also what tyres do use guys recommend for say 30% off road use
thanks in advance
Posted: Fri Jan 11, 2008 11:03 am
by dfoyl
You can go as far as about 215/65/14 without issues - depending on wheel offset. If you use Pathfinder or the like 6-bolt pattern you will likely have a slightly wider stance and the inner edge of the tyre will clip the mudflap on full-lock. If you lift it you won't have this problem though...
Dean.
