Spare wheel issues - Brumby
tommo
Post by tommo » Wed Jan 03, 2007 5:52 pm
Hey everyone,
I've got an '89 brumby which is pretty well still stock at the moment, but I've just bought 14" wheels and as a result the spare doesn't fit in the allocated space under the bonnet anymore.
Just wondering what other brumby owners have done about this problem.
I thought some people might keep a standard 13" under the bonnet as a spare but you'd be pretty screwed if you were out bush somewhere.
And i don't really want to have a spare taking up space in the tray..
So has anyone done anything inventive like modified the space in the engine bay to fit a bigger wheel somehow??
Anyway, I appreciate any suggestions you can give me.
Tommo.
brumbyrunner
Post by brumbyrunner » Wed Jan 03, 2007 7:22 pm
age old problem.
try jaming an aired down fullsize spare under the bonnet and carry a 12v compressor.
I just put mine in the back.
92 brumby
Post by 92 brumby » Wed Jan 03, 2007 9:19 pm
i have a set of racks on mine with a spare 15by 29inch and a set of hella rally 4000 spotties that does the job and i think lookes pretty tough too the racks set me back 80 bucks from auto barn made a rectangle plate to bolt front rack to back put wheel in middle and a couple of 200mm m12 bolts and nylocks
Post by steptoe » Thu Jan 04, 2007 10:05 am
different air filter arrangement can make more room
mine being on lpg and tank in tray, been thinking late falcon wagon spare carrier under where petrol tank should come out
Jack
Post by Jack » Thu Jan 04, 2007 11:03 am
I usually drive around with 13's on my Brumby and only change over to 14's when I plan to go 4WDing. My 13 spare sits under the bonnet all the time, and the 14 spare goes in the tray with the rest of my recovery kit.
If you want to carry a 14 spare and keep the tray clear, then an option to look at is to stow it on the cab roof. Buy a pair of roof bars from any auto shop. Ratchet strap the 14 spare directly to the roof bars, or fab up a marine ply mounting board. Some downsides of a roof mounted spare are that it'll increase fuel consumption, raise your centre of gravity, increase wind noise, and you'll be more prone to snag on low branches when off roading.
Jack
1999 Outback (some mods)
1989 Brumby (more mods)
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Jan 04, 2007 10:03 pm
Or you could make a mount to have it against the rear of the cab.
The long road ahead
dwayneb
Post by dwayneb » Fri Jan 05, 2007 8:00 am
I have a storage system in the tray of the Brumby, keep my 14inch spare under it, and also have a standard 13inch spare under the bonnet
tommo
Post by tommo » Fri Jan 05, 2007 9:17 am
Hey thanks fellas,
I like the idea of the roof racks, but i hadn't thought about all that raising the centre of gravity and stuff..
Definitely gives me a few ideas though.
Thanks again.
Tommo.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Jan 05, 2007 9:54 pm
If you are going to put it on the roof the added weight up there wont make much difference to the CG as most 14in rims have extra offset which gives you a wider stance anabling more stability. Plus with Subaru Lift kits the body is raised and the main weight the engine and box and left at the smae road height its the tyres that provide the lift of the eingine
The long road ahead
maudsland
Post by maudsland » Sat Jan 06, 2007 9:04 am
i have a 185/65/14 under my bonnet fully inflated, mind you i have a webber fitted with a small aircleaner
tommo
Post by tommo » Sat Jan 06, 2007 9:52 am
That's exactly the size wheel/tyre I'm trying to fit in at the moment and it definitely doesn't fit, plus I'll be putting bigger tyres on them soon. Not sure what a webber is though? engine?
maddog
Post by maddog » Sat Jan 06, 2007 4:15 pm
I've also got 185/65 14 under the bonnet - I took out the spare wheel support bar and 'modified' it to allow more room. Just bash it with large hammer cos there's enough room under the bonnet...it will fit...honest!
88 GL Touring Wagon - getting better all the time... or was until Skippy got in the way one night... writeoff now :(
98 Forester - wotaluvlycar! (belongs to missus) ;o)
91 Liberty Wagon in immaculate condition - can't believe how much nice it is, mine! ;)
Brumby Boy
Post by Brumby Boy » Sat Jan 06, 2007 5:28 pm
I have this same problem tho i havnt done anything about it... yet
Webber is a brand of carby that alot of people on here use. in particular the 32/36 off a 2L ford cortina. give more power and allow a smaller air filter to be fitted
RIP 1992 Brumby
tommo
Post by tommo » Sat Jan 06, 2007 7:27 pm
Ahhhh I see, thanks for the info Brumby Boy. :mrgreen:
I had another go this arvo trying to squeeze the 185/65 R14 in there and actually succeeded. (with great difficulty) although it just about blocks access to the engine oil dipstick and with any bigger tyres there'd be no chance.
Think I like the idea of mounting it up against the back of the cabin the best so far...
maddog
Post by maddog » Sat Jan 06, 2007 8:48 pm
...would also make room for when you fit a turbo ... :o)
Post by El_Freddo » Sun Jan 07, 2007 7:30 pm
Ever thought of a rear mount wheel carrier we use on wagons? I think a brumby with one of these would look good, it'd also free up your tray space... Just a thought.
tommo
Post by tommo » Mon Jan 08, 2007 4:24 pm
Yeah actually, I had thought about one of those rear mount systems, they usually have a jerry can holder on the other side don't they?
Anyone know who supplies them, or do they have to be custom made?
Brumby Boy
Post by Brumby Boy » Mon Jan 08, 2007 5:35 pm
yea i have had this thought too, but have so far been too lazy to do anything about it yet. does anyone make one for the brumby???
RIP 1992 Brumby
Post by steptoe » Wed Jan 10, 2007 10:37 pm
I am a great fan of silicon spray - that might help to get it in place !!
maudsland
Post by maudsland » Sat Jan 13, 2007 2:37 pm
I knew a guy who was a fan of silicon spray, he got onto it while he was in jail, know idea why
