Largest tyre to fit into MY/Brumby spare holder ?
Moderator: Junior Administrator
185/65/15
Running 185/65/15's and in the spare, the holder does not centre.
- IMG_20170717_224333195.jpg (116.91 KiB) Viewed 12777 times
- IMG_20170717_224254850.jpg (116.15 KiB) Viewed 12778 times
- IMG_20170717_224316340.jpg (113.69 KiB) Viewed 12778 times
- IMG_20170717_224242611.jpg (113.82 KiB) Viewed 12783 times
Re: Largest tyre to fit into MY/Brumby spare holder ?
UPDATE !!!
For some totally unknown reason, the exact tyre that is shown in the above photo of a MY touring wagon - will not fit into the same space in a 1989 Targa Brumby !!!!???
the aircleaner seems to be 10-15mm closer to the firewall and is preventing the tyre from slipping down into the firewall/bonnet sill slot.
As far as i know there are no issues that should have made the engine retreat 10mm to 15mm rearwards - but there we are.
Its not an issue related to engine height/lift kits etc as its not the engine height that is the issue.
Ahh well.
Ahh well.
- Silverbullet
Weird!
I wonder...could the touring wagon and the Brumby have different intake manifolds/carbie versions, which would affect the position of the air cleaner?
Interesting about the space difference with the touring wagon vs the targa brumby. What year model is/was the touring wagon?
Does the targa brumby have the stock intake and carb fitted, or is there an L series intake/Weber carb in the mix here? If stock it does seem odd. Maybe someone put replacement engine mounts in backwards if that’s even possible??
Good info none the less!
- Bantum
Sorry I'm not near my Touring wagon to be able to check that measurement ... :/
Mine is an Auto if that makes any difference in the mounting position of engine forwards an extra few mm ?
