List of 4x140 PCD Wheels ...
Post by Bantum » Thu Nov 28, 2013 2:15 am
Ok,
I've started to pull together a list of 4x140 PCD wheels that I've found around the traps and made a list that can be downloaded here :
List of 4x140 PCD Wheels - V1
Do Note : That the above is only the first draft, so if you see something that I've missed or have any new ones to add, Welcome to post them here & I'll update it ... 8)
Add : Ok - here is the Second edition ...
Subaru 4x140mm PCD Wheel Reference Guide - V2
Add : 3rd Edition ...
https://www.facebook.com/groups/1984658 ... 441867442/
Add : Fourth Edition ...
https://www.facebook.com/groups/1984658 ... 685882912/
Credits : I got most of them from here ( old site ) : http://www.indysworld.com/80s/general/w ... heels.html
Updated site : http://www.indysworld.com/subaru/galler ... heels.html
Addies : Here are some other web sites worth checking out : This thread is also worth checking if your after hub / center caps : Center Caps ...
Also Note : I can put all the wheels on here as well, but they will have to be spread out over several pages ( 10+ at a guess ) I'll see what you guys think first before I go doing that ... ;)
Regards, Bantum ...
P.S. - Can somebody make this a sticky later ... ;)
Edits : 2013; Add Credits + Mttechsuba Web Site + Pinterest + Toymods + Centercaps ... 2014 ; New & Latest Version ... 2020 ; Revise & Add Fourth Edition ...
ATV Wheels ...
Post by Bantum » Thu Nov 28, 2013 12:30 pm
I find it interesting that some ATV's do have the 4x140 PCD, although I'm not sure they would be suitable for a car application ...
Like they may not clear brakes & are not rated for large loads etc. ... :)
I'll post any that I do find here for interest sake :
12x8" Carter v.1
Found here : http://www.ruckhouse.com/index.php/popu ... -v-12.html
( edit : links dead )
There are a few others, will add when I find them ... :p
Cheers, Bantum ...
phil nelis
Post by phil nelis » Thu Nov 28, 2013 8:52 pm
The only problem is you must make sure the centre hole in the rim is only 94mm so that when it fits onto the wheel studs it also sits flush on the locating lugs on the hubs otherwise all the load is only supported by the wheel studs. I have speedy style sunraisers on my car and they have a 107mm centre hole so i made some hub rings to suit.
4 Spoke Wheel ...
Post by Bantum » Sun Dec 08, 2013 11:23 pm
Saw these on Gumtree :
Subaru 4 Spoke Wheel
Worth a look ... :)
Cheers, Bantum ...
Post by RSR 555 » Tue Dec 10, 2013 11:04 am
$300 is a little high but they have been cleaned up nicely. I have 2 sets of these off my MY EA81 turbo sedans
Some more Ye Olde wheels ...
Post by Bantum » Thu May 22, 2014 12:01 pm
Here's few new ( Ye Olde ) wheels found recently :
Add : Link to go here :
13x5.5" made by Performace ( Not sure of its type 'name' though )
and this one :
Add : taken from here : showthread.php?t=25053
I'm not sure what it is yet ... ( think it could either be a Jackman or an early wagon wheel copy )
Can any one help ?
Cheers, Bantum ...
sublime
Post by sublime » Thu May 22, 2014 5:10 pm
Bantum wrote:
and this one :
Can any one help ?
Cheers, Bantum ...
That last one looks like a Peco Star rim. I know they did make rims for 4x140 Subarus but certainly not many!
They have a 'square cut' look compared to Sunnies/King rims and a small square sticker (you can just make the remnants of it on the top left spoke in the picture) that stated PECO STAR.
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
Awsome ...
Post by Bantum » Fri Jul 04, 2014 11:26 pm
Thanks sublime, I will add it to the list ... :)
Another web site to check out : http://www.mttechsuba.com/subaru-wheels-and-rims/
( I've added this to header post as well )
Cheers, Bantum ...
More ...
Post by Bantum » Wed Jul 23, 2014 11:13 am
Steptoe has found another :
Anybody know what it is ?
Cheers, Bantum ...
Willy Fisterbottom
Post by Willy Fisterbottom » Wed Jul 23, 2014 12:22 pm
Simmons
Post by Bantum » Wed Jul 23, 2014 8:25 pm
Thanks Willy - just looked up Simmons on Google, the only reference I could find mentions they are the 'Vista' model - no sizes though ... :(
I'm assuming they are 13 x 5" for now ... :)
Cheers, Bantum ...
Post by steptoe » Wed Jul 23, 2014 11:20 pm
think the text with pic link says 15" x 6" , left out three piece compomotive rims. Every second car featured in fast fours n rootaries in the nineties and noughties had the famed east coast made Simmons ! These are a version of V5 Simmons, just no ornate work in the large flat centre. Gogle Simmons V5 in picture google.
About $400 each way back then, think Willy priced 17"s and fell over :p $770 each !
More ...
Post by Bantum » Thu Jul 24, 2014 3:13 am
Thanks Steptoe, will add it to the list ... :)
While searching for the above, came across a few more ...
An ATV t9-pro-mod 14 x 7" :
Which can be found here : http://www.itptires.com/wheels/utility-atv/t9-pro-mod
And some Chinese copies of the Freeman racing wheel & Peugeot 504 And 505 replicas ...
model S300 14 x 6" :
model S308 14 x 6" :
Details here : http://1523870.en.makepolo.com/products ... 01735.html
Haven't seen the later one before, make of that what you will ... :p
Cheers, Bantum ...
Tuning Forks ...
Post by Bantum » Fri Aug 22, 2014 1:33 pm
Saw another new one on FB today : Thanks to Kade ...
It's an 8 'Tuning Fork' spoke wheel ... :p
Anybody know who made these / more info ?
Edit : These are ATV wheels Apparently ... :)
Cheers, Bantum ...
henpecked
CERCHI GOTTI for PCD140
Post by henpecked » Fri Aug 22, 2014 4:45 pm
Dean.nabbe
Post by Dean.nabbe » Fri Aug 22, 2014 8:22 pm
does anyone know where i can get 15" 4x140?
1987 Brumby.
still to come:
2"exhaust
winch bar
Update ...
Post by Bantum » Fri Aug 22, 2014 9:42 pm
Thanks Henpecked ... Although I already had that Gotti type on the list, I will add the name ... ;)
Dean, You can do a search on ebay / Gumtree / Yahoo for them ... & do check the list for available types
( linked here on first page ) as they are out there, just not easy to find ... :D
I will have to go & update the file now, will advise when posted ... :twisted:
Cheers, Bantum ...
Custom Made ...
Post by Bantum » Sat Aug 23, 2014 12:55 pm
Dean.nabbe wrote:does anyone know where i can get 15" 4x140?
I just found these :
Can be found here : http://www.allwheels.com.au/product.php ... 250&page=1
This from site :
15 X 6.5 BLANK 4H/5H
PCD from 98 to 120
OFFSET from -10 to +30
15 X 7.5 BLANK 4H/5H
PCD from 98 to 120
OFFSET from -15 to +25
Other Options: 2 Tone Anodize Color (Pink/Green/Purple/Yellow/Blue) available & Gun Metal
You would have to check with them on prices & whether the center is suitable for 4x140 pcd ... :(
Cheers, Bantum ...
Willy Fisterbottom
Post by Willy Fisterbottom » Sat Aug 23, 2014 2:19 pm
Bit of a feed on facebook at the moment, some bloke running ATV wheels on he's Brumby.......
Pugs anyone ...
Post by Bantum » Sun Aug 24, 2014 1:15 pm
Do tell willy ... :p
Meanwhile I found some more pug wheels to look out for :
More details to be had here : http://www.aussiefrogs.com/forum/techni ... 504-a.html
Cheers, Bantum ...
