correct nuts for L Series RX H mags ??
Post by steptoe » Thu Mar 21, 2013 7:07 am
Just wondering the L Series RX H pattern mags used wheel nuts other than our usual dome nuts of all other 4x140 steelies, maybe more surface area ?
T.Farm.Brumby
Post by T.Farm.Brumby » Thu Mar 21, 2013 8:45 am
Pretty sure they're the long nut variety. Don't know what you'd call them, but that's what came with the H-Style RX mags I was advertising before. Don't know if they were stock or not but they seem like the right thing :)
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'89 Brumby "Brumbylicious"
'03 Outback "Uma"
'05 Forester
Post by steptoe » Thu Mar 21, 2013 9:58 am
was sort of wondering if it was a nut with greater surface area contact with the rim ... rather than the length - my fault, should have stated that fact !
Post by RSR 555 » Thu Mar 21, 2013 11:42 am
On my RX they are just like the standard chrome ones, just black
T.Farm.Brumby
Post by T.Farm.Brumby » Thu Mar 21, 2013 12:35 pm
Hmm, well maybe the chickie just had the long ones on so they were easier to get at? The recess in the alloy is pretty deep.
Surface area I'd have to agree and say the bog stock chromed nuts (dome) would have the most.
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
sublime
Post by sublime » Thu Mar 21, 2013 2:18 pm
RSR 555 wrote:On my RX they are just like the standard chrome ones, just black
+ 1
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
Post by steptoe » Thu Mar 21, 2013 2:40 pm
thanks, I like the stats - 2 out of 2 RX owners have black nuts.
Might just have to accept that 283,000km and 28 years is OK for a wheel bearing to crumble slowly with a few hints along the way.
Post by El_Freddo » Wed Mar 27, 2013 4:30 pm
steptoe wrote:thanks, I like the stats - 2 out of 2 RX owners have black nuts.
Too much boost?? :p
steptoe wrote:Might just have to accept that 283,000km and 28 years is OK for a wheel bearing to crumble slowly with a few hints along the way.
Yeah maybe, otherwise one could be seen to be asking too much of their subi! Pretty good effort though!
Was it the rear left that went first?
Post by steptoe » Wed Mar 27, 2013 9:05 pm
Right rear and has been quiet ....no rumble, just the occasional rotor run out squish squish noise and the visble play
Post by RSR 555 » Wed Mar 27, 2013 11:10 pm
Too much boost?? :p
More likely because they've been kicked too many times :(
Post by steptoe » Mon Apr 08, 2013 1:59 pm
and not that this thread has such a related to topic title anymore ....bearings have held up, make no noise, was getting a squik, squik noise from time to time, found the rear hub or bearings had some play. From afar away as Halifax UK ,in 9 foot snow drifts, 1111giles made comment he had a problem drive him nuts until he replaced the split cone washer, tapered? washer and nut. Having spent more time thinking about this repair approach over the last four weeks, I had a bright idea to flog nice washers from my Vort wreck in readiness for this job. Ripped rear wheel off to get split pin out, undid nut with my fingers - where was its 180 foot pounds ? eh ?? Noticed the cone shaped washer had worn into the slight tapered washer, donors did not, so whacked them on , jumped on my extended breaker bar and 36mm socket and done. Test drive nice so far.
Giles baby ! Many thanks for throwing that comment in ! I was worried I'd be on a search for a new rear disc hub :effenphew:
Post by RSR 555 » Fri Apr 12, 2013 8:38 am
biggest problems with the taper washer is when they are worn they get an 'edge' lip on the taper face, this stops them tightening up to the required tension. The other thing to check is where the taper was sits in the hub, this needs to be perfectly round and not dented in any way.
Post by El_Freddo » Fri Apr 12, 2013 7:04 pm
RSR 555 wrote:biggest problems with the taper washer is when they are worn they get an 'edge' lip on the taper face, this stops them tightening up to the required tension.
I'll admit I've been dodgy with this taper washer. If it has an edge on it I grind it down flat again and re-use it.
I've not had a problem doing this... yet :(
