Just wondering if anyone experienced same as me with L Series and MY part time 4WD boxes and low profile tyres, and diff binding.
Running 195/50 15"s and getting diff bind causing need to thump back into FWD on dirt roads and wet tarmacadam (that's what I believe its full name is!)
Was not doing it on my 185/60 14"s all of which were same tyre, the 15's however have a ring in or two....two different generations of Roadstones on the back, BJ Zenon 1's? on the front.
Could just be that the different brands and gens of tyres even though same size may have different rolling circumferences (actual not theoretical) causing this or is it that a 50 series tyre has less squishy give?
I am waiting for drive and time to fit new BJ257 ball joints, a nice tight rack end before fitting some new Bob Jane Zenon X7's (some of the last made in Adelaide before they went off shore) and a front wheel alignment before I will know if it is tyres brands and wear rate than ratio
tyre aspect ratio affect non AWD 4WD box diff bind?
Different brands have different rolling diameters even when claiming to have the same tyre sizes. I've seen many Outbacks and WRXs that have blown centre diffs due to this same issue. This usually happens after long drives.
- littlewhiteute
Yes, that exactly right. DO NOT run different brand tyres on any 4WD or AWD vehicle.RSR 555 wrote:Different brands have different rolling diameters even when claiming to have the same tyre sizes. I've seen many Outbacks and WRXs that have blown centre diffs due to this same issue. This usually happens after long drives.
Gary
Gary
