the tyres are pretty much 29inch(235/75R15) and are friggin massive, i really want to fit these tyres under the car. The rims have a slightly more -ive(i think) offset which will move the wheel closer to the car and wont stick out like the speedies im currently running.
Im not at all worried about the rear, they should fit very easy. The front however will be a different story! Im thinking about making custom radius rods to push the wheel further forward in the arch as the only thing i can see holding me back is the wheel hitting the firewall.
Before you say it, i know theyre chrome, if they look shithouse ill get them painted!
See the pic below. Please note the car is sitting very low due to a flat tyre and en-even ground there. You can see the size of the tyre next to my spare 27inch kumho muddie with 100% tread
watch this space, as i'll do a detailed writeup with a bucketload of pics.
 the last hub is at an engineering shop getting drilled cos i couldnt be stuffed with it anymore.
