How to determine your "Tyre Flotation"
Posted: Mon Jul 21, 2008 6:05 pm
There is a slighty tedious, but absolutely totally foolproof way to settle the tire argument/flotation issue for yourself, forever.
1) Go to a public weigh bridge , weigh each end/axles of the vehicle, loaded and unloaded.
2) On a hard smooth surface, jack up the front end of vehicle, both tires off the ground. Make a sand pad about 2cm deep, 250mm wide, by 300mm long under each tire on the ground.
3) Lower the vehicle onto the sand pads with normal road pressure in the tires and gently bounce on the front end.
4) Jack the front end into up the air again and measure the "tire contact patch", both the length and width and record it somewhere.
5) Smooth out the sand pads to erase the "contact patch".
With the front end still in the air, lower the tire pressures to minimum "off road pressure" . Lower the vehicle onto the sand pads and bounce gently.
6) Jack vehicle back into the air and measure the "tire contact patch" again and record your results.
You will find, like I did, that the contact patch has increased, only very, very slightly in width and has increased in length very dramatically.
6) Repeat the process for the rear end of the vehicle.
7) Multiply the length by width of your contact patches to obtain the total "area of flotation" for each tire, at normal "highway" pressure and "off road pressures. The two results will be your "road area" flotation" and your "off road area" flotation.
Now comes the calculations. When I did this, I used square inches rather than square centimetres.
Divide the total vehicle weight in kilos, by the total "square inches" of rubber contact patch. This will give you a kilogram per square inch of tyre contact area.
When I did this to my previous 4wd with 30" x 10 x 8 tires , 15'' rims
I found that the flotation area was about 3.5" x 8" (28 sq") for each wheel, at normal highway road pressures (32psi)
Lowering to my minimum off road pressure of 12psi, increased only 1/2" in width to 8.5" and over tripled in length to 10'' long. (85sq"")
My total vehicle weight of 2240kg divided between 4 tires at 28sq" each, gave 2240 divided by 112 sq " =20kgs of vehicle weight per square inch of tyre at highway pressures.
Total vehicle weight of 2240kg divided between 4 tires at 85sq" each, gave 2240 divided by 340 sq" = 6.58 kilos per square inch of tire at off road pressures of 12psi.
Soooooo.........lowering my tire pressures from 32psi , down to 12psi, to drive "off road" effectively tripled my flotation......
Tire pressure on the ground surface reduced from 20kg per square inch down to 6.5kgs per square inch.
(for comparison, a 6 foot man of about 85 kilos , wearing a size 10 boot, places a pressure on the ground of about 5kg per sq inch. I know, I did this to myself also......
Other advantages of lower pressure
3 times the number of tire lugs in contact with the ground surface gave vastly better traction.
Rolling over obstacles like rocks and logs was vastly improved and vastly more comfortable, due to the tire conforming to the shape of the obstacle better, therefor again allowing better traction and impact/shock absorbtion.
Any disadvantages when running ?....
Two slight ones that I noticed.
I had to run the tires on the narrowest rim size suitable for the tire, in order to protect my rims(mags) from damage, when on rocky trails and to prevent the bead from dislodging(causing deflation) at lowest off road pressures.
I always had to pump up the tires when returning to the highway, 12 psi on the highway can quickly cause overheating in the sidewalls and potential blowouts at highway speeds. I bought an onboard compressor
Michael
Michael
