28's on a lifted impreza
- cruzingbrumby
What would you have to do to get 28's on a lifted impreza ?
I am thinking a 2 inch lift, but the struts are the problem, the impreza have the lowest lower spring perch of all, would you need forester or outback struts to get them to fit?
How much massaging of the inner guards would need to be done, I suppose that you would need either forester or outback wheels with the greater offset as well.
Anyone seen a setup like this or have one that could comment
- cruzingbrumby
You can fit anything on anything if you try hard enough :P
http://image.fourwheeler.com/f/SubaruGL ... on-33s.jpg
- vincentvega
- cruzingbrumby
Will have a 2 inch lift kit for sure, looking at 28's as there seems to be a lot more choice in the 215/70/16 size which equates to more availability and cheaper price, I spent ages looking for a reasonably priced 215/65/16 before when i had the lifted lib but was not many to be found and the price was always high.
- vincentvega
- cruzingbrumby
- cruzingbrumby
